S
Sarah Sadlow Posted on Mar 24, 2016
5B00 printer error code, what is this?
MP490 Cannon Printer shows error code 5B00 on read out. What is does this code mean and how do I fix the problem.
5 Related Answers
Anonymous
  • Posted on Dec 06, 2007
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
smarty32
  • Posted on Mar 07, 2008
SOURCE: check printer
Printer and computer is RAM base structure.
They cannot record any memory without battery.
please follow the steps with screwdrivers
1. Unplug the printer (NO power or any connection)
2. Flip the whole thing Up side down
3. At the bottom, you can see there are screws
4. they are for the generator of the power supply
5. Take them away
6. And slowly take away the "brown" box”
7. Then you will see a power cord links with printer
8. Use a very small driver to release it with real care
9. Leave it for 30 minutes
10. Put it back together .... done
After that
Also, from other, but work....
The reset procedure (for canon MP130) is:-
Turn on the machine
(1) Press MENU
(2) Press SCAN COPY SCAN to enter service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
DONE !
Mukesh Kumar
  • 3230 Answers
  • Posted on Jun 19, 2009
SOURCE: Check Printer (5B00)
try this -
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3) SET ABS-M LEVEL TO 0
4) OK
good luck
Anonymous
  • Posted on Dec 18, 2009
SOURCE: printer cannot print-message (5B00)
it says check printer 5B00. what do I need to do?
pineworks
Clive
  • 4362 Answers
  • Posted on Jan 25, 2010
SOURCE: error code 5b00 on canon MX300 multi printer
Try It might work it works with most canon priters
Hi you can try
Solution:
  1. Turn on the machine
  2. Press MENU
  3. Press SCAN COPY SCAN to enter service mode
  4. USE > to got to NVRAM ACCESS
  5. Set ABS-M LEVEL to 0
  6. Set ABS-P LEVEL to 0
  7. Press STOP to EXIT
All The Best: Pineworks
Top Cannon Office Equipment & Supplies Experts
Dennis
Grand Canyon Tech
Grand Canyon Tech
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
