Electrical Supplies Logo
L
Lindsay Philip Westhoven Posted on May 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is error code 52030
Won't connect to internet
Pete Warr
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on May 13, 2016
Pete Warr
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
13586
Points
168
Unable to connect to your wireless network, most likely rejected the security info.
1helpful
Can not connect to internet on my wii error code 52030
It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console
Lost internet connection reading code 52030
Error Code: 52030
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
2answers
2helpful
2answers
I have netflicks and is has quit working, i have a error code 52030
That error code means that your settings for your router are incorrect. Try to re-enter your settings and see if that fixes the issue.
When I try to connect to the Internet it keeps giving me a error code 52030
Error 52030 is a security settings error built into the Wii. This means the Wii is either incompatible with your router's security settings or your router isn't able to assign the Wii an IP address (which means it can't register it onto your network).
Nintendo has provided official information for solving this problem here: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=lang
My wii will not connect to wireless internet error code 52030
If you get an error code of 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
I have an Error Code 52030 on my WII. What does
it means that u are trying to connect to wifi but there is no wifi around so go 2 tech support for wii and enter the error code.:)
1helpful
2answers
Wii shop channel won,t work
YOur internet isnt allowing the wii to access the shop...
4helpful
3answers
Error 52030 in internet connections
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right afer started to fall in place perfectly...my wii started connecting to my router and never had the same error code ever since.
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
