The three-digit code should be noted. To make it easier for you to unlock your luggage the next time, write down the three-digit code on a notepad or enter it into your smartphone.
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
SOURCE: cannot remember my code to unlock my samsonite breifcase
Turn your suitcase upside down. At this position all your numbers look
upside down. Now with the help of a torch light you should see a small
gap above the rotating thing (the one with which you change your
number) Take the first rotating thing and rotate from 0 to 9, at some
particular number you can see a small hole inside the small gap which I
have mentioned before. Do the same for the next 2 rotating thing.
When you are done you can see the small hole(a tiny spring like material is seen in the hole) in all the three small gaps.
Now you can open the number lock.
