SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/saht70
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
SOURCE: I have Logitech X-230 speakers. The left speaker
CHECK THE POWER SUPPLY TO THE SPEAKERS
REPLACE ITEM IF POWER TRANSMISSION IN NIL
SOURCE: the right speakers logitech Z 5500 do not work
try buying a new optical cable or change some settings on your tv.
