SOURCE: massey ferguson 3655
sounds like the seals are gone on the 4wd shaft, it takes oil pressure to keep the 4wd off, but if the seals are worn the all passes through and the 4wd will not dissingage, you will need a experianced michanic
SOURCE: Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
SOURCE: What kind of oil goes in a Massey Ferguson Tractor
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
SOURCE: What sort of oil is used in the gearbox of a
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
SOURCE: water pump leaking into motor oil on a 451 massey ferguson
You have a blown head gasket.Don't use till its fixed keep draining out water oil and add fresh oil if you have to start tractor at all
