This seems to be a symptom of a configuration error, which can be fixed by resetting the router to factory default. Do this by finding the (often partially hidden) reset button on the device, and pressing and holding down the button, with the power on, till lights start flashing on the router. Let go of the button and allow the router to reset (can take a minute or two). You will now have reset the router to factory default. To connect to your ISP, you'll need to enter your account details (and any other specific information) provided to you by your ISP. You will also have to set a name and password for the wifi section of your router (if it has wifi) if you don't want it to be freely accessible by everyone within wifi range.
Once you lay out all the necessary details regarding the Linksys router error 2118, now it's time to have a look at how we can remove this particular error code.
In this section, you will find various solutions regarding this Linksys router error. Therefore, follow the methods and apply them to troubleshoot Linksys router accordingly.
Check and Improve Internet Connectivity
We have already mentioned that poor or weak internet connection can be a principal cause for this Linksys error. Therefore, if you encounter the same error with your Linksys router, then you have to check the internet connectivity.
To check the internet speed, you can attempt different online internet speed checking tools to figure out the necessary details. After getting the report, if you find that you are connected with an unstable internet connection, then you require to connect with a strong and stable internet connection.
Thus, you can contact your internet service provider. They will surely help you to resolve internet connection issues. Once the connectivity issues are gone, the Linksys router error will be fixed automatically.
Update the Version of Firmware
Having the updated version of Firmware is critical to the functioning of the router. In case, you don't have the updated version of Firmware and use the outdated version, then you might encounter this particular error.
Therefore, verify the software of the router to check that the firmware is up-to-date. If this is not the case, then you require to get the updated version of Firmware. But, if you don't know How to update the Firmware, then you can carry out the steps below.
Step 1: Firstly, you need to go to the Search box that is on the Taskbar and look for the Device Manager. Once you locate it, click on it. Then, choose a category to see the name of the device, and then right-click on Firmware.
Step 2: Once you are done with the above step, click on the "Update Driver" button. After that, locate and select the "Search Automatically For Updated Driver Software" option. If an updated version of Firmware is available, then you need to hit the "Install Driver" button to install that.
After that, you will get all the necessary instructions on the screen to complete the process. Once you do that, the Firmware will be updated to the latest version, and the Linksys error 2118 will automatically be removed.
Deactivate the IPv6 Settings
If the Linksys router has IPv6 settings in it, then this can be another potential cause of this error. Once this error code appears in your router, it will hamper the performance of your router.
Therefore, to sort out this matter, go to the Setting Panel of the Linksys cloud account that you have. After that, navigate to the Connectivity section and locate the "Internet Settings." Once you locate the "Internet Settings" you will find the "IPv6" option. Now, you need to hit the option to disable it, When it is done, tap on the Save Changes button and then confirm the process by hitting the OK button.
In this way, you can perform this entire process and ultimately resolve the Linksys error. But, in case, this Linksys error still appears, then you can go for the next fix.
Restore all the Default Factory Settings
Sometimes, there can be something wrong with the settings of the router. You will need to reset it right if you want to fix this Linksys error. However, it can be quite troublesome to figure out which settings to put in. In such situations, you can revert all the current settings to the factory defaults (recommended).
You will be able to perform this task by launching the Settings app of the Linksys router. Once the Settings opens, locate the restore the factory settings option. Once you locate it, you need to tap on it.
Thereafter, a few instructions will pop up on the display screen. You have to follow them accordingly to revert the settings to the factory settings. Once you are done, simply reboot your device and check if the Linksys error is eliminated from your device.
Uninstall the Antivirus Software
If you have any third-party antivirus software installed on your device, then it can conflict with your device and as a result, Linksys error 2118 appears. In that case, it is recommended that you uninstall the antivirus software temporarily. Check out the section below to learn the entire process.
Step 1: At first, locate the Windows Home key on your keyboard. Once you locate it, press it along with the "I" key to launch the Settings window. As an alternative way, you can navigate to the Search box and write "Settings" and hit the Enter button.
Step 2: In the Setting window, click on the "Apps And Features" option. After that, scroll down the page and locate the Antivirus Software, and tap on it. Now, choose the Uninstall button.
After finishing the uninstallation process, you have to reboot your device. And once your device restarts, check if the issue gets resolved. But, if the above methods fail to resolve the issue, then the next and the last fix, mentioned below will surely fix the error.
Setup your Linksys Router Properly
To set the Linksys router properly, you need to perform the usual setup process. First, you need to connect to a strong and stable internet connection with your Linksys router.
After that, go to the login page and log in. Here, you need to put all the admin credentials. In this way, you will be able to log in to the router. Now, you will have all the necessary instructions for setting up your Linksys router. Simply follow all the on-screen prompts. This will finish the setup process of the Linksys router.
Lastly, you need to restart your device and check whether the Linksys router error 2118 gets removed from your device.
To Conclude
Hopefully, with all the above-mentioned methods you will be able to fix this particular Linksys error code 2118 on your own. But, even after following the above methods, if you are still stuck with the same error, then you need to interact with an expert professional to resolve this matter with the most appropriate solutions.
