Camping, Backpacking & Hiking Logo
J
John seaton Posted on Sep 21, 2017
Thetford caravan toilet repair - Camping, Backpacking & Hiking
  • David Ellis Rhea Sep 21, 2017
    Hi John seaton, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Find an RV dealer and ask them.
5 Related Answers
Anonymous
  • 68 Answers
  • Posted on Mar 30, 2009
SOURCE: thetford caravan fridge freezes all food in fridge
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Anonymous
  • Posted on Apr 26, 2009
SOURCE: Recently purchased a caravan with a thetford c-200
you may have this already but try
http://www.thetford-europe.com/web/show/id=51498/langid=42
John Long Shipton
  • 63 Answers
  • Posted on Jun 13, 2009
SOURCE: how do we empty and maintain our thetford porta
Go to www.thetford.com.
Click Customer Support then Product manuals and download manual in PDF format.
John Long Shipton
  • 63 Answers
  • Posted on Nov 06, 2009
SOURCE: Hi, have a built in thetford toilet in my caravan.
Don't send money. Just go to thetford.com and download info.
Some tips - if seal is old and breaking up make sure you recover all the bits which have fallen into the flush water tank. If new o-ring seal not available use outdoor silicone sealant and allow to set for 48 hours before adding anything other than a small amount of water to test flush action. Electric circuit includes a fuse and microswitch which are both contained within the flush water tank but you are unlikely to have problems with these items.
Anonymous
  • 7 Answers
  • Posted on Mar 25, 2010
SOURCE: I have a thetford toilet in my caravan and cant
Here is a link for the Manual for your model http://www.thetford.com/HOME/PARTS/PortableToilets/PortaPotti365PDFs/tabid/669/Default.aspx
Top Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
