Air Tools & Compressors Logo
K
Kevin slaunwhite Posted on Feb 04, 2018
I have 3 brand new pastloade air framing guns that will only fire2 or3 clips of nails and then won't fire anymore
5 Related Answers
Editor925
Dean
  • 285 Answers
  • Posted on May 31, 2009
SOURCE: How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
Anonymous
  • 154 Answers
  • Posted on Jun 11, 2009
SOURCE: will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Anonymous
  • 142 Answers
  • Posted on Sep 23, 2009
SOURCE: Gun stopped driving nails, air escapes from top,
has the gun been cleaned and oiled, i think not.
take the head bolts out of the top of the gun. make sure you pay attention to how everything comes out so you can put it back together.
shake the gun upside down so that the piston comes out. wipe everything down with any petroleum based cleaning solvent to remove all the gunk and reassemble.
pour about 10 dropsof oil down the air input, let it sit there about 5 mins and hook up the air and it should work
Anonymous
  • 1949 Answers
  • Posted on Jan 15, 2011
SOURCE: My Arrow Nail Master 2 stopped firing after I
check that 2 are not jammed together/and safty is able to be pushed
H2_Brad
Brad
  • 425 Answers
  • Posted on May 17, 2012
SOURCE: My nail gun won't fire nails and is blowing It
Stop using it and take it in for service. If it is leaking air then an o-ring or seal may have failed (most likely guess) and it needs to be replaced.
Top Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
