Car Audio & Video Logo
B
Brooks Knight Posted on Jun 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to wire a 6 ohm audiobahn ALUM10N subwooferto reduce ohms to a single chanel amp
Tim Brauer
Level 2:
Sergeant:
  • Expert 152 Answers
  • Posted on Jun 03, 2018
Tim Brauer
Expert
Level 2:
Sergeant:
Answers
152
Questions
0
Helped
40702
Points
568
Unfortunately if you only have the one woofer there isn't really any safe way to do so but if you had a pair of woofers you could in theory wire them in parallel thus creating only a 3 ohm load but your amp must be able to work at such low ohms otherwise you WILL blow up your amp.
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Jan 04, 2008
SOURCE: 6 ohm speakers - 8 ohm amp
This is a tough one due to the info at hand, but I'll take a stab at it.
I'll assume that your amp is not a tube-type amp. I'll also assume it is a relatively recent "solid state" design. If those assumptions are correct, connecting a 6 ohm load to an 8 ohm amp should not cause significant overheating or amplifier instability.
Dalynn Turner
  • 346 Answers
  • Posted on Apr 19, 2008
SOURCE: wiring configuration 800a2
http://mobile.jlaudio.com/support_pages.php?page_id=161
Here are the diagrams for running dual voice 6 ohm sub's.
Anonymous
  • 8546 Answers
  • Posted on May 19, 2009
SOURCE: replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
Anonymous
  • 655 Answers
  • Posted on Sep 13, 2009
SOURCE: Want to bridge 2 channel amp to push single 4 ohm dvc sub
Hello k_rabbit89,
A 4 ohm DVC sub can be wired in series like you described for an 8 ohm load or the voice coils can be wired in parallel for a 2 ohm load.
If your 2-channel amp isn't stable down to 2 ohms when the channels are bridged (most 2-channel amps are only stable to 4 ohms when bridged), you do not want the voice coils paralleled. The amp will overheat, go into protection mode, and eventually fail completely. A sub with 2 ohm voice coils would be a better fit. That way, you could series the coils for a 4 ohm load and the amp would operate OK with the channels bridged into that load.
But anyway, for the best power from THAT amp to THAT sub, your best wiring solution would be to wire each voice coil to a separate channel. The problem with that is that the signal to each coil needs to be EXACTLY the same or you will have one coil trying to move the cone out while the other one tries to move it in. You can closely approximate identical signals on the output side by using the same input to both channels. Do this by using only one RCA connection (either right or left channel) from your head unit and split it with a "Y" cable.
Hope this helps.
Anonymous
  • 3 Answers
  • Posted on Feb 28, 2010
SOURCE: can I mix 6 and 8 ohm speakers?
Most Yamaha HTR's are high current receivers so setting the receiver to 8 ohms and running the 6 ohm speakers shouldn't be a huge problem. I wouldn't crank the volume though if i were you but at a decent level you should be fine.
Top AudioBahn Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Anonymous
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
