Air Purifiers Logo
w
william Charles Bain Posted on Aug 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I put in my truck to take out the cigar smoke like I have before and the ozone smell wasn't there ,the fan was working but no clean ozone smell like normal
Don A
Level 3:
  • Master 5,185 Answers
  • Posted on May 08, 2024
Don A
Master
Level 3:
Answers
5185
Questions
5
Helped
1533851
Points
27234
Check Ventilation: First, ensure proper ventilation by opening the windows and letting fresh air circulate through the vehicle. Sometimes, poor ventilation can affect the effectiveness of ozone treatments.
Clean Your Vehicle Thoroughly: Ozone treatments won't remove the sources of odors, so any food particles or gunk that's contributing to bad smells in the vehicle will just start to smell again later. Vacuum your vehicle thoroughly and use wet wipes to scrub down any hard surfaces or dashboards.
Run the Ozone Generator Longer: If the odor persists, consider running the ozone generator for a longer duration. Typically, it's recommended to run the generator for at least 30 minutes. However, you can extend this time if needed.
Air Out the Vehicle: After running the ozone generator, air out the vehicle for 2-3 days until the ozone odor goes away. Ozone smells like a funky version of chlorine bleach, so once that odor is gone, you're good to go.
5 Related Answers
Anonymous
  • Posted on Nov 09, 2008
SOURCE: No ozone smell
This generally indicates that the plate is cracked or not making proper contact. Pull the plate and look very closely as even a tiny microscopic crack anywhere on the plate will produce these results.
Anonymous
  • 43501 Answers
  • Posted on Nov 16, 2009
SOURCE: ozone smell
When the unit is clean it will produce more ozone. If the unit is a bit oversized then it becomes worse. As an installer I have to be carefull to not oversize these units. O3 is harmless and actually will only stay in the air as O3 for about 1/2 hour. Because of this it will not build up in the air. O3 also in a powerful disinfectant and will help kill mold and bacteria in the air. As soon as the filter gets a little bit of dust on it the O3 production will become much less. Run your fan continuously for a day or so and it will go away.
Anonymous
  • 13 Answers
  • Posted on May 29, 2010
SOURCE: no ozone smell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
Anonymous
  • 4 Answers
  • Posted on Sep 11, 2010
SOURCE: My Flair stopped working correctly,so I purchased
pull the unit out of the enclouser and check the bottom for a circuit board and on the board their is a glass fuse see if it is blown. Also on that same board their is a small round black fuse that is labled f21 it is a 400ma 250 volt fuse on my unit and is soildered in this fuse is just for the ozone
Anonymous
  • 80 Answers
  • Posted on Jun 15, 2012
SOURCE: ecoquest fresh air not omitting ozone
Did you clean the plate contacts with alcohol? How old is the plate? Is the glue that holds the grid in place turning brown? If it is, it may need to be replaced. Call (336) 499-2505 and ask for free email supplemental cleaning instructions before you do anything else. The instructions may help you solve the problem.
Does not produce ozone, I have replaced the fuse, it has been cleaned and the amber light is not on.
it's possible that the ozone generator inside has gone bad. The only way to really know is to remove it from the unit and then test it with a power supply w/correct voltage of coarse. You will smell the ozone immediately if it works upon testing. (clean fresh smell) If it does need replaced, it's an easy fix for anyone with electronics knowledge. You will need to match up the numbers to get the correct replacement. Many are available on Ebay. Always disconnect the power to the unit before taking it apart. Hope this helps, Dave
1helpful
Hi-I have the Living Air XL. It's out for repair because I cannot smell the distinct clean smell it normally puts out. The repair guy just called and said it's fixed and running, but the green light bulb...
He probably cleaned the unit and restored the plaques. Green light or no green light, it doesn't affect the production of ozone. If still in doubt, when you go to pick it up, have him operate fit or you before you leave the store. I've had one 7years and the green light hasn't worked for three years. I clean it regularly and it still produces ozone when needed. Regular, routine maintenance is the answer.
My xl-15 air purifier works but it does not blow out air with the purified smell. I think I see people calling it ozone.bthere used to be what looked to be an illuminated orange light behind the fan. It...
Easy. You need new plates in the machine. They cost about $15 a piece. Google 'ozone plates for XL-15' & sources will come up on where to buy them. Remember to clean the plates every 30-45 days w/ 50-50 solution of ammonia & water & a tooth brush on these plates. Dry thoroughly w/ hair dryer before putting back in machine.
I no longer smell the ozone smell that i used too.
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers.
3helpful
Ozone smell
3helpful
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
XL-15 Classic Living Air emmitting Foul Odor!!
Ionizers do cause a bad odor to happen. I work in the copier business and do work around machines that can cause an ozone to happen when there are ran. Copiers like ionizers can cause an ozone to happen because the air particles are being electrically charged. The smell isn't good to be breathing in as well.
Here is an EPA report about ionizers
The Consumer Products Safety Commission is going to be making a decision about the health effects on ionizers by the end of the year. Their decision can effect selling ionizers all together.
This industry should have been regulated years ago and after what happened to Sharper Image this year due to their arrogance it isn't doing the industry any favors. They went out of business because of Consumer Reports findings and tried to sue them for it.
If you really want the air in your house cleaned, the best way to do it is using a hepa filter.
Unit stopped smelling
Whenever you clean or replace the plate, you must also clean the contacts that touch the plate, and all supports for the contacts. Clean them with 70% or higher isopropyl alcohol and Q tips. You should also clean the ionization point with a Q tip and alcohol, remove and clean the fan and oil the fan motor front and rear with a drop or two of sewing machine oil. Replace the fan so that it is flush with the end of the shaft. Make sure that the contacts are firmly against the ozone plate when you replace it. They sometimes barely make contact and then don't work well. You can bend them enough to make them fit firmly.
1helpful
3answers
XL15
The ozone plates need to be cleaned monthly to work effectively. You can get an owner's manual for free from the manufacturer's website, it's at:
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pdf
The manual has a description of the type and frequency of cleaning of various parts of your air purifier. Hope this helps!
Top Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you an Air Purifier Expert? Answer questions, earn points and help others
