Arvind Galyan Posted on Sep 15, 2018
My denon avr 1312 gives chattering sound from surround speakers. 2.1 Channels are working perfectly, problem is with 5.1.
5 Related Answers
Robert Johnson
  • 395 Answers
  • Posted on Jan 13, 2008
SOURCE: Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
Anonymous
  • 304 Answers
  • Posted on May 24, 2008
SOURCE: No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
Anonymous
  • 93 Answers
  • Posted on Nov 06, 2008
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
A
Anonymous
  • Posted on Nov 08, 2008
SOURCE: Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Anonymous
  • 119 Answers
  • Posted on Mar 03, 2009
SOURCE: Denon AVR-588 Sound Delay
FIRST, IF YOUR USING HDMI CONNECTIONS IN THE DENON HDMI SETUP YOU HAVE TO TURN THE AUDIO DELAY ADJ. ON
SECOND, THE DELAY TIME ADJ, FOR OTHER SOURCES IS LOCATED ON PG 27 IN THE MANUAL, HERE IS THE LINK TO DENON SITE WITH MANUAL
http://www.ca.denon.com/AVR-588-OM-E_102.pdf
Top Denon Audio Players & Recorders Experts
woodzowl307
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
