SOURCE: Intermatic timer will not turn pool pump off
If your timer is not turning off the pump its probably wired incorrectly. Check the wires on the back of timer as it should work the same as a regular light switch. They may be reversed.
SOURCE: Intermatic T104R clock not working.
here is a link to the wiring diagram, u may not have the clock motor hooked to the right terminals. http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
SOURCE: Intermatic Pool timer will not turn off... I have
If the pool pump timer is not working, first look and see if the clock dial is moving, if not then you need to check the 120volt breaker that feeds it ,, then you would check the connections on the timer to be certain that they are correct.
SOURCE: Intermatic pool timer E10694 does not turn on. It
Open following link for troubleshooting checklist:
If dial is rotating, then tripper might need to be replaced.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
The problem here is I cannot identify E106 timer
Intermatic product Index, and pool and spa catalog do not show that specific model among digital or mechanical timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Maybe you have T106 2-speed pump motor?
Add a comment with in-focus photo of timer you posted on Flickr for possible identification.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
