SOURCE: How do I record a personal greeting?
You can download the manual below: http://telephones.att.com/docMgt/public/art/286/1818_manual.pdf
SOURCE: greeting was somehow erased
Hi Sherrie, I am sorry to hear about your husband, I will do what I can to help. I am fairly confident on that model that if you push the greeting button, then delete it will erase the message for good. Also, if the memory power failed, then it would reset to the default greeting and erase all messages and greetings. However, if the unit has options for multiple greetings (ie. default greeting, greeting 1, greeting 2, etc., then perhaps the default greeting may have been selected, while your husbands greeting is still there but is recorded under say greeting number 1. If that is the case, you can select it to play his greeting instead of the default greeting to have it play. I would find out for you but my computer is having trouble opening the manual on the Panasonic site, so here is the link. Look under "greetings" in the index. Hope I helped. Thanks, CG http://service.us.panasonic.com/OPERMANPDF/KXTM150B.PDF
SOURCE: How to record greeting message
Page 21 of the manual: http://service.us.panasonic.com/OPERMANPDF/KXTG5100M.PDF
1 Press and hold [GREETING] until
“Record greeting after the beep” is
heard.
2 After the long beep, talk clearly,
about 20 cm (8 inches) away from
the MIC (microphone).
• The elapsed recording time is
displayed.
• If you record for over 2 minutes, the
unit will stop recording.
3 When finished, press
[GREETING] or [STOP].
• The unit will play back the recorded
greeting.
• To change the greeting, start again
from step 1.
SOURCE: how do you record greeting? i lost my manual for kx-tg9331t
Check on the web page for panasonic .
Type in your unit number after you get to the manual area.
SOURCE: AT&T E5965C phone answering machine does not record incoming mess
My E5965C dosenot record in comi8ng messages.
