Electrical Supplies Logo
Tony Lawrence Posted on Dec 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I turn off a intermatic time switch model t101 off
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on Dec 20, 2018
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
513752
Points
3433
What exactly is your question, stop the clock from controlling and stay in off position or instantaneous switch to off?, but will cycle on and off in the future.
There are dogs that control the on and off and the dogs can be moved or removed.
There is a shiny white lever below the disk that when operated will switch on and off power to the load being controlled.
5 Related Answers
jeltey
Scott Jelt
  • 44 Answers
  • Posted on Dec 04, 2008
SOURCE: how to program Intermatic model T101-70
Do you have the screw on trip pieces? They look like little arrows with a thumb screw on them. Some of them should say On, some Off Place the on trips over the time you want the lights to com on vice versa for off. To set the time pull out on the yellow time wheel and rotate until the arrow that is pointing down is over the current time. I hope this helps.
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jun 26, 2009
SOURCE: Intermatic T101 does not turn on using the
There are two different trippers. 'On' and 'off'. The off will not turn it on. Get an 'on' tripper.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 207 Answers
  • Posted on Jul 08, 2009
SOURCE: T101 Intermatic Timer will not turn lights on or off
You have a weak timer motor. The T101 is notorious for it. I have 6 on my property and have had that problem numerous times. You need to replace the guts of the timer.
Anonymous
  • 557 Answers
  • Posted on Dec 10, 2009
SOURCE: define line vs load
Simply put line is where the power is coming from, and load is where the power is going to. Your breaker panel would be the line side, and the device you are powering is your load.
Testimonial: "thank you"
Anonymous
  • 565 Answers
  • Posted on May 08, 2010
SOURCE: T101
Here's the wiring diagram:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
The wiring is as follows:
Connect _both_ the incoming and outgoing neutrals (white) wires to the "A" terminal. The incoming [(LINE) (hot) (from the breaker or source)] black wire is connected to the #1 terminal and the outgoing (LOAD) black wire is connected to the #2 terminal.
Both of the bare or green wires are twisted together along with a 6 inch or so pigtail using a red or yellow wire nut. The pigtail is then connected to the green "GR" screw on the enclosure.
Top Intermatic Electrical Supplies Experts
wadingriver
wadingriver
ADMIN Andrew
ADMIN Andrew
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
