Exercise & Fitness Logo
C
Christine proulx Posted on Apr 30, 2019
My Fitbit charge 2 will not sync with my phone tried everything and the batterie last only one day?
janhendrikal
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 22, 2025
janhendrikal
Contributor
Level 1:
Answers
Questions
0
Helped
111
Points
Here are the most common fixes:
  1. Bluetooth reset
    • On your phone, go to Bluetooth settings, "forget" the Charge 2, then re-pair it through the Fitbit app.
  2. Restart the Charge 2
    • Plug into the charger, then press and hold the button for ~4 seconds until you see the Fitbit logo.
  3. App reset
    • Log out of the Fitbit app, restart your phone, then log back in.
    • Make sure the Fitbit app has permission to use Bluetooth and location services.
  4. Firmware update
    • Check if there's a pending firmware update (sometimes sync won't work until it's updated).
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Oct 04, 2008
SOURCE: LG KS20 Battery Level Issue
...so guys, after one week of investigation I finally managed to fix this annoying issue. I made an update of the ROM - I had the German unbranded version 10a and I flashed it with the English (Turkey) version 10d (issued in May 08) and to my surprise, the battery indicator started to work properly. For more detail how to flash your device follow the link below (of course you must know what you do so read it carefully because you will do it on your own risk)
Another solution is to send the device to LG / distributor as a warranty repair, they will probably replace your battery. Few users posted that they have done it this way and it also helped.
Here you can find all necessary to flash your device with new ROM version:
http://forum.xda-developers.com/showthread.php?t=405945
Netopjer
Anonymous
  • 1952 Answers
  • Posted on Dec 11, 2008
SOURCE: Battery life last less than 30 minutes
you will try new battary then same problem check ur battery holder
Anonymous
  • 16 Answers
  • Posted on Jun 14, 2009
SOURCE: Ipod shuffle 2 gen has no battery left and wont charge
you'll probaly have to install the software again
Anonymous
  • 12 Answers
  • Posted on Mar 10, 2010
SOURCE: the batter life is bad
two things.
1. as with any rechargeable battery, you want to train the battery to utilize it's full capacity. train by draining battery completely till device shuts off. leave off until fully charged. this method is called training and sets its threshold capacity.
2. when replacing a rechargeable battery ensure that the replacement battery operates with the same "mAh" or more. (i.e., I purchased an extended battery for my cell. the original battery was 1100mAh and the extended battery is 2300mAh) this value represents the battery's power output per hour.
* When buying a replacement for any rechargeable device pay close attention to this information before making a final decision.
rhl1999
Rich Laue
  • 26 Answers
  • Posted on Nov 02, 2015
SOURCE: My fitbit charge gets stuck on the finishing up step.
To reset the charge stick it in its charger, make sure harbor is charging then hold the bottun until it vibrates.
Top Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
