SOURCE: I have a yamaha electric golf cart. The lights
I bet that it is an simple as a fuse that blown out. Try replacing the corresponding fuses.
SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
SOURCE: Hi I just brough a yamaha golf cart and wanna know...
check the serial number there is normally and date with in it.
SOURCE: 1987 EzGo Gas power Golf Cart will not run. It has gas and new battery
You have this in the wrong product category.
Throttle position sensor
