Coffee Makers & Espresso Machines Logo
P
Patricia McCloskey Posted on Jul 04, 2019
I need a jug for the coffee machine - Coffee Makers & Espresso Machines
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Aug 23, 2007
SOURCE: Buy new coffee jug?
try this --> www.nelsonappliance.com
Anonymous
  • 15935 Answers
  • Posted on Aug 14, 2010
SOURCE: I have a Breville CM3 Coffee machine. The Anthony
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Anonymous
  • 8909 Answers
  • Posted on Nov 04, 2010
SOURCE: hi there we have a
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Anonymous
  • 8909 Answers
  • Posted on Jan 06, 2011
SOURCE: NEED NEW LARGE GLASS JUG
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
I hope this helps.
javeedcare
Javeed Khan
  • 316 Answers
  • Posted on Jul 05, 2011
SOURCE: i need to buy a new jug for delonghi magnifica
http://www.appliancefactoryparts.com
THE ABOVE SITE WILL HELP YOU.
REGARDS.
DON'T FORGET TO RATE ME
I need the glass jug for a Logik Select coffee maker but can't find parts in SA?
This is a very popular item, I am attaching the link and a pic to order from Amazon. The jug is out of stock but in the upper right of the pic I circle where you could submit a request to be notified when the jug is in stock again.
https://www.amazon.co.uk/LOGIK-LO0012-Logik-Coffee-Jug/dp/B00LD0K6RI
Hope this is helpful
With the water jug full of water, the machine still keeps saying refill water.
unplug from outlet for 20 minutes. If the jug is removable, thoroughly clean the area where the jug sits and the part of jug that sits on the coffee maker. If that doesn't work, look online for the makers web site / phone number and ask for help.
Delonghi coffee machine ecam23. Milk comes out of jug when turning machine on and milk also comes out after the water when cleaning the spout on the jug.
I think the ECAM has a second solenoid at the front near the milk jug. That solenoid valve might be stuck open.
>> service agent
Gordon Ramsay PGRCM001 Professional Coffee Machine I need to get a replacement jug for the aforementioned coffee maker--do you know where i can get this? thanks
Hi John !!
It seems that we have the same problem together !! I'm afraid I won't help you much ...I'm trying to find the jug from France ...Here the machine is "unknown"!!
..whenever you find any adress ...Thanks to help me too !!
regards !!
The machine goes on but when the button is pushed, it makes noise as if it is making coffee but no water comes out. This occurs periodically. Does it simply need descaling/
you should try that first,,,i do it this way,,,,get some kettel cleaner,, mix it up in a jug in warm water first ,,then tip it in the coffee maker and catch it in the jug when it come out again so you can tip it back in,,,,run it through a fuw times,,,then flush the coffee maker out with lot and lots of fresh water before you make coffee,,,or you could be a little unwell drinking kettel cleaner?
4helpful
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Need braun type 3041 glass jug
Try at www.amazon.com or www.amazon.co.uk they have a number of spare glass jugs for sale.
Regards
Alan Hood
ami-man
UK
1helpful
Small rubber gasket/plug needed for Russell Hobbs coffee maker
Hi there, between the two of us, we have one complete working model. Have you still got the glass jug. My last camping trip was on a sloopy site, and my caravan was at an angle and I had not stowed the glass jug, resulting in the inevitable smashing of the jug. Either you can have my machine, or can I have your glass jug. Im happy to pay postage to you for you to send me your glass jug.
Yes its a great bit of kit, and still makes great coffee.
Like you we have another machine at home, and so this one is on the caravan, for holiday weekends, it would be great to get your jug and make you feel good that one whole machine is out there and still delievering great coffee
thanks
James
Bournemouth UK
57 BH6 5HR
01202 777389
07761 383532
Top Coffee Makers & Espresso Machines Experts
ADMIN Andrew
ADMIN Andrew
john h
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
