Expert
- Posted on Aug 21, 2009
Re: My desktop has msg: problem has been detected and...
As per your issue since you cannot boot to safe mode or last known good configuration.probably your Operating system file is corrupted.Tried to boot from OS xp media or vista and try to repair the operating system.Change the boot sequence to boot from cd in the bios.
i did see error of a problem has been detected and windows has shut down. can't boot for cd rom, can't go to safe mode. rand ide dianostics hardware passed. but microsoft said it is hardware so both dell and microsoft deciding who is who. FYI that stopo 0x0000007E etc etc was there also.
what i would recommend is a checkdisk /p
if this also does not resolve then.. please reformat your computer..
btw does it give you another error message..
something like this - "NTLDR is missing. Press Clt+Alt+Del to Restart"
or is it something like this
A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps: Check to be sure you have adequate disk space. If a driver is identified in the Stop message, disable the driver or check with the manufacturer for driver updates. Try chaging video adapters. Check with your hardware vendor for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode. Technical Information: *** STOP: 0x0000007E (0xC0000005, 0xF85F9AD9, 0xF898B7A4, 0xF898B4A4
