Posted on Aug 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot install my network wireless printer. It
I cannot install my network wireless printer. It appears to be installed but will not print.
Anonymous
Level 2:
Sergeant:
  • Expert 151 Answers
  • Posted on Aug 21, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
151
Questions
0
Helped
146148
Points
534
Try installing it by adding the printer using its IP address
to do this:
Click add printer then select printer attached locally (unchecked automatically detect plug and play printer)
Then click next
then select create new port then select Standard TCP/IP Port
Then click next
Then enter the IP address of the printer
Then click on next then finish
Try printing
Hope this help
3 Related Answers
Anonymous
  • Posted on Jan 26, 2008
SOURCE: wireless printing
The following assumes you are running MS Windows. It mostly is based on XP, and different versions will surely not be exactly the same, since it IS Microsoft. In any case, there are more details and tools, such as Wizards, in the Help And Support Center (see below) which you should refer to.
First, the laptop and the desktop both must have the same Workgroup name, which is set in System Properties. (Via System in the Control Panel, or right-click on My Computer and choose Properties.) Of course, their Computer Names must be different. Also, remove any Computer Descriptions, since this is known to cause problems - especially when mixing different versions of Windows.
Second, you need to turn on File And Printer Sharing on the desktop PC. This may already be turned on, but if not, you may be prompted to do this, maybe by using the Network Setup Wizard, when you try to Share the printer.
Third, you need to Share the specific printer. In Printers And Faxes (via the Control Panel) right-click on the printer and then left-click on Sharing in the pop-up menu. There you can choose to share the printer and give it a name for the network. If it chokes here, you may need to turn on Sharing as mentioned above.
If the laptop and desktop are different Windows versions, then drivers for both versions may need to be installed. The printer Sharing window may help with that. If not, refer to Help And Support, which should be available by clicking on Start. In some versions of Windows you may need to search within Help for a key word such as print or network. Or, you may need to dig into a menu of topics.
If you used the Network Setup Wizard for any of the above steps, it probably set the Windows Firewall settings ok, but if you are using a third-party firewall, you may need to change some settings there to allow the connection to be made.
Of course, with the printer connected to the desktop, the desktop needs to be turned on in order to print from the laptop. Another option is to get a small print server and connect the printer through it to a port on the router. That way, the laptop could print even when the desktop PC was off. The whole Sharing setup described above would not be needed, although you might do it anyway, in order to share files between the computers. This might also allow (or force) the printer to be moved to a more (or less) convenient location.
Before getting a print server for a multi-function printer, try to confirm with the server maker that it is known to work with that model of printer, or at least with similar units of the same brand. Some of the mfp's have problems if they aren't connected directly to a PC. Getting the latest drivers could help with that.
Whether shared through another PC or directly through the network, the new printer needs to be Added in the Printers And Faxes window. In Printers And Faxes (via the Control Panel) click on Add a Printer, either in the column on the left (if you have it) or in the File menu. You should be able to choose to add a network printer, then browse the network to select it. If you don't find it there, look in My Network Places for clues. For example, make a folder on the desktop PC called Test, then share it, and make a file in it called test.txt, then see if those show up in My Network Places.
As you can see, there are lots of places where it could be broken, but this outline should at least help you to know what sorts of things to look for.
Anonymous
  • 106 Answers
  • Posted on Jul 07, 2008
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Anonymous
  • 3344 Answers
  • Posted on Oct 21, 2011
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Can I print using non-wireless mode? Can I print away from my home network? I have installed printer on my laptop using my home wireless network.
    If you're not connected to your wireless network, you can print to the printer via the USB cable. Simply insert one end of the cable into the usb port on the back of the printer and the other end to your computer. Wait until your computer completely recognizes your printer before you print (a notification should pop up on your screen).
    Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolve your concern, your rating will be greatly appreciated. Thanks.
    Top Gestetner Office Equipment & Supplies Experts
    Norman Weimar
    Norman Weimar
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
