Apple iPod touch Logo
Posted on Aug 31, 2009
I forgot my i touch passcode - Apple iPod touch
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2307
Points
12
1.Connect your Ipod Touch to your Pc
2.Once connected hold the home button and the power button keep holding it until the apple comes out
3.then let go of the power and still keep hold of the home button then your itunes thing will come up with a cd and a usb wire on your pc it will say itunes has detected a ipod in recovory mode restore your ipod with itunes
4.click OK to that
5.click restore and just restore
6.enjoy!!!!!!!!
5 Related Answers
Anonymous
  • 342 Answers
  • Posted on Jun 20, 2009
SOURCE: forgot my passcode
Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
Anonymous
  • 30 Answers
  • Posted on Jul 23, 2009
SOURCE: forgot ipod passcode
simply plug your ipod into itunes to unlock the code
Anonymous
  • 392 Answers
  • Posted on Sep 04, 2009
SOURCE: have a ipod touch, but passcode is fogotten.
you can reset its password....but you'll lose all your data. Here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Mrteaze
Tim Degenstein
  • 101 Answers
  • Posted on Sep 30, 2009
SOURCE: I forgot my passcode for my ipod touch.
It seems like you will have to restore it which i have researched and seems to be the only way, this will sadly erase all content so if you are willing to put back your music/videos etc.. back, then go for it you do this by
1) Connect the iPod Touch
2) Press and hold sleep+home until the device reboots.
3) Keep holding until that "please connect me to iTunes"-screen appears
4) iTunes says something about having detected a touch in recovery mode. Allow it to do its thing.
If you get the -18 error, proceed:
5) Disconnect the iPod Touch
6) Close iTunes
7) Reconnect the iPod Touch
8) iTunes launches and shows message as in step 4, but this time, the recovery will work
Anonymous
  • 68 Answers
  • Posted on Oct 15, 2009
SOURCE: Forgot passcode to ipod
You'll need to restore the software with iTunes. Select the iPod in iTunes, under the Summary Tab, select Restore. You will then need to resync it as well.
Forgot id and password
If you forgot the passcode for your iPhone, iPad, or iPod touch, or your device is disabled Follow these steps if you've forgotten your passcode, or if a message says that your device is disabled.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
3answers
Reset my password on iPhone and i pad
iPhone must be recovered on a PC or Mac to solve this problem.
CLICK HERE
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
1helpful
Forgot passcode and wont unlock how do I unlock it?
Try to remember your passcode because the solution that I'm going to recommend to you will wipe out all the data from your iPod touch.
If you totaly forgot, the only thing you can do is to put your iPod touch to DFU mode and then restore.
Click here for step by step instruction on how to do that.
For more iPod touch / iPhone tips, click here.
Forgot ipod passcode
4helpful
2answers
FORGOT PASSCODE
If you can't remember your passcode, you will have to use iTunes to restore you Touch. Remember that restoring will erase eveything on the Touch, make sure you have made a backup of your data first.
Here is detailed steps on restoring:
http://support.apple.com/kb/HT1414
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
woodzowl307
SmartAviator
SmartAviator
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
