I just built a new computer with a foxconn 925xe motherboard. i used a ati radeon pci express video card. when i turn the system on, my monitor does not turn on. the light on the monitor stays orange. can you please assist me fix this problem?
For the first time install windows,i can connect with the PCIex out put to Monitor...it's work. But after install the Radeon driver... the driver was conflict with PCIex HD 3650 with on board Radeon X1200. after reboot... the monitor can't display anything until i change the connection to onboard graphic card. i try to solve it, but i can't.
Please advice...
I used... Asus M2A-VM RADEON HD 3650,256MB
Please advice...
AnonymousDec 12, 2008
have an problem with an Foxconn 925 xe motherboard..... te problem is that i cant boot the windows ...and if i se or boot devices OFF and i let the first boot device DC-ROM i will encounter an error like DISK BOOT FAIL......what should i do PLS HELP ME have an problem with an Foxconn 925 xe motherboard..... te problem is that i cant boot the windows ...and if i se or boot devices OFF and i let the first boot device DC-ROM i will encounter an error like DISK BOOT FAIL......what should i do PLS HELP ME
You can't post conmments that contain an email address.
I have the same problem. How ever I have another pcie MB and the video card is good. The Foxconn pcie slot is bad. I bought everything from geeks.com and they don't have any more boards. .
First check wheather power cable is join correcly at the monitor
then check video card placed correcly in agp card
or see the monitor cable join correctly at pc
first check wheather power cable is join correcly at the monitor then check video card placed correcly in agp card or see the monitor cable join correctly at pc change the video card and use it first check wheather power cable is join correcly at the monitor then check video card placed correcly in agp card or see the monitor cable join correctly at pc
i used pci express not agp
I used...
Asus M2A-VM
Please advice...
