All question need 'make model (what it is)'. Otherwise it is a guessing game. Question was in Audio Players, so moved to Misc.
E10 - Water supply is slow or insufficient. This error will be displayed when the unit senses that the water supply is insufficient and is taking too long to fill the tub with water.
Jun 10, 2016
The E10 error code indicates the control does not see a proper fill. Here are a few things you can easily check. Always
unplug or de-energize electrical equipment before removing covers or
attempting service. Be careful and wear appropriate hand protection when
working around sharp metal parts.
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets 1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems. 1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
E10 code indicates there is no water supply.This can be confirmed by :
Shut off the faucet to stop water supply to the washer.
Disconnect and pulling the supply hose off the washer to confirm the E10Code
Opening the faucet and watch for running water if you have water
Can be caused by bad pressure switch
Can also be caused by clogged pump
also by too low of a drain hose height. Check for clean filters of the inlet water line. Check that the drain hose was assembled as per the manual's instructions.
I believe E10 means there is a draining problem. Check your drain hose and see if that is where it should be and not clogged. If that is okay, most likely your pump is clogged.
E10 also means that your cold water is coming in too slow, disconnect the
cold water hose and check to see if the screen on your washing machine
is clogged. If the screen is clean and the hose has good pressure then
you will need to replace the water valve on your machine--- this is the
piece that the hoses directly connect to.
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
