Crafts & Hobbies Logo
D
Daneen Allemang Posted on Oct 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I connect my Cricut expression to my computer?
FastHarley
Level 3:
  • Master 761 Answers
  • Posted on Dec 02, 2019
FastHarley
Master
Level 3:
Answers
761
Questions
Helped
367155
Points
2528
1. Plug in the machine and power it on.
2. Connect the machine to your computer with the USB cord or pair it via Bluetooth.
3. Go to design.cricut.com/setup in your browser.
4. Follow the on-screen instructions to sign in or create your Cricut ID.
5. Download and install the Design Space plugin when prompted (help article).
6. You will know the setup is complete when you are prompted to make your first project.
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
Stacy Boring
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 29, 2019
Stacy Boring
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
679
Points
5
Yes you can. You need a cable that will go from your machine to your computer. It's usually just a simple printer cable. Then you have down download some software from Cricut.com called Cricut Craft Room. Then you should be good to go. :)
4 Related Answers
Anonymous
  • 9 Answers
  • Posted on Jul 05, 2009
SOURCE: need to update firm ware on cricut expression so i can use sure cuts alot could not find at cricut.com
Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
balboul@gmail.com
Anonymous
  • 13 Answers
  • Posted on Mar 25, 2010
SOURCE: Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
ADRIAN
  • 313 Answers
  • Posted on Jul 25, 2010
SOURCE: My Cricut Expression keeps turning on and off.
I have one of these machines stripped down on the bench now with this problem. I have located the fault to a power relay which is sealed but must have burnt contacts as it is not passing the power to the machine to power up. I am still looking for a source of 18 volt coil relays with 10 amp contacts to fix this one. If not I may have to modify the circuit to overcome this problem.
Anonymous
  • 6 Answers
  • Posted on Feb 18, 2012
SOURCE: I need a manual for a cricut expression
www.manualsonline.com/
Top Crafts & Hobbies Experts
ADMIN Andrew
ADMIN Andrew
Tim Hofstetter
Tim Hofstetter
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
