There is another method for locating the codes for the device you wish to control. Although I do not know the specific remote model you have it should work. First though try any of the codes listed here that you have not already tried.
0002, 0179, 0184, 0209, 0236, 0463, 0479, 1479
On a majority of the Comcast remotes you have to follow special instructions for setting up combo devices.
For your TV/DVD.
You may also need to enter a separate code for controlling the TV for volume control.
If you still have not found a code that works then use this method to search the stored memory for codes.
Again since I am unsure of which model remote you have there is a slight variation to this with other models.
Instead of pressing the Channel+ to scroll through the codes you need to alternate between the Power button and TV button.
If you still are no closer to relaxing while watching a DVD. You may want to consider programing the TV/DVD as separate devices.
All this seems like a real pain so good luck.
I hope this helps, but if not respond with the remote model# and maybe I can do more with that.
