Conair Weight Watchers WW-87 Body Fat Glass Scale Logo
Anonymous Posted on Oct 17, 2009
Can't reset scale
I can't reset scale after changing the batteries. The readings appear to be in metric
5 Related Answers
Anonymous
  • Posted on Mar 14, 2009
SOURCE: I have a tanita tbf-612
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Anonymous
  • Posted on Nov 21, 2008
SOURCE: setting is in metric instead of pounds
On my model, there is a button on the bottom that slides back and forth to choose the wanted setting. My scale is about 5 years old.
Anonymous
  • Posted on Mar 08, 2009
SOURCE: bought w/watcher glass scales and changed battery
Incorrect in what way?
Anonymous
  • Posted on Apr 19, 2009
SOURCE: metric instead of pounds
You didn't mention brand name or model number, so not sure about your specific case. However, on my scale, there is a switch or button near the battery compartment. It allows you to change the measurement between stones, pounds and kilograms.
Anonymous
  • Posted on Jun 05, 2009
SOURCE: When I turn on scales, Err appears which is an
I contacted Salter and unfortunately the scales cant be repaired. Could you please remove my request. Thank you.
Top Conair Health & Beauty Experts
Narseman
Dennis
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
