RCA RS2622 CD Shelf System Logo
Posted on Dec 28, 2007
Clock We have misplaced the manual for this, and for the life of me, I CANNOT remember how to change the clock! Help! (and thanks!!) P.S. Happy New Year!!!
  • 1 more comment
  • Anonymous Jan 10, 2008
    Lost instructions want to change clock time
    have moved house and lost instructions need to change clock time, can you help?
  • BonnieS Jan 22, 2008
    Try and try, but cannot change the clock...and we are missing our manual also. If anyone can pdf a copy of the manual, it would be a big help. Thanks
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1749
Points
5
I too HAD this problem but, thank-god (today/Jan.26,2008) I found the solution to the - TIME & PRE-SET RADIO STATION - problem. I found this page: http://sanyoservice.com/osb2/showitem.cfm?sort=ItemID&isID=&Category=5&Unit=12&startpage=1&currpage=3&startrow=13
Then downloaded the PDF file of the closest model the - SLIM3010 & now my stereo works correctly once again!
Your Welcome,
Amanda C. Muller
MyNewBMW320i@hotmail.com
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1040
Points
0
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Anonymous
Level 1:
  • Posted on Jan 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1040
Points
Hold down the button on the unit that says "clock.timer", right under the clock. After holding it down for a couple of seconds, the display will read "select clock or timer". Let up the button and click it briefly again to show the blinking clock. Use the fast forward and rewind buttons to change the hour, the previous chapter/next chapter buttons right below them to change the minutes. After you've set the time, click the clock button once more to lock the time in.
Anonymous
Level 1:
  • Posted on Jan 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1040
Points
Hold down the clock button until it flashes and then use the arrow keys to change time
Daniel1957
Level 1:
  • Posted on Jan 18, 2008
Daniel1957
Contributor
Level 1:
Answers
Questions
0
Helped
1040
Points
I think you have the wrong model. The PolyConcept/RCA Chaplin
841.670 does not have a clock in it (at least mine does not).
A
Anonymous
Withe the unit in the OFF position, play around with the 'set' button. It's the little square button on the left side, above the left tape deck, to the left of the 'clear' and 'play'. The hour will blink, to set it, press the arrow buttons to the right: 'down' and 'up'. When the hour is to your preference, hit 'set' again, and it'll go to minutes. Use the arrows again. 'Set' again returns the unit to normal.
Anonymous
Level 1:
  • Posted on Jan 04, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1198
Points
With power restored, the clock re-sets to 00:00 and blinks. That's normal. use the tape/CD fast forward button to set the time. Hold down to increase the time quickly, release. Then tap the fast forward/ fast reverse buttons to increment up or down.
JohnC
Anonymous
Level 1:
  • Posted on Jan 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1040
Points
http://www.fixya.com/support/p183507-jvc_mx_d301t_shelf_system/manual-17363/page-27
Setting the Clock The timers depend on the clock: the clock must be right for the timers to work as you expect. You can set the clock whether the Unit is on or off. Note that the clock must be set, otherwise the timers cannot be set. 1. Press the SHIFT button. 2. Press the 1 CLOCK button. The “CLOCK” indicator on the display light up and the clock time blinks. 3. Press the SELECT 5 + or 4 – button to set the time. Pressing the 5 + button increases the time and pressing 4 – decreases the time. Pressing the button continuously advances or decreases the time in 10 minute intervals. 4. Press the 8 SET button. The blinking time display changes from a blinking display to a steady display and the clock timer starts from 0 seconds. CAUTION: If there is a power failure, the clock loses its setting. The display shows “0:00”, and the clock must be reset.
Anonymous
Level 1:
  • Posted on Jan 31, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2006
Points
Press and hold CLOCK until the hour flashes
Press SKIP BACK or SKIP FORWARD to set the hour
Press CLOCK to shift to minute digits
Press SKIP BACK or SKIP FORWARD to set the minute
Press SET to save settings and quit.
Top RCA Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
