Hi vrytrigg
If you still have the old RAM inserted, try removing it and see if the new one works on its own. If it does then your RAM are incompatible with each other as they may be running at different clock speeds although they will both be compatible with your system. should you manage to re-boot the PC, there are a few sites online that can scan your system to let you know what type of RAM you should buy.
Hope this helps!
Nic
