Lands Phones Logo
Anonymous Posted on Nov 06, 2009
I cant initialize disk, I/O Device Error How can I restore hard drive as new from factory
Anonymous
Level 3:
President:
  • Master 414 Answers
  • Posted on Nov 06, 2009
Anonymous
Master
Level 3:
President:
Answers
414
Questions
Helped
159891
Points
3594
This problem to an i/o device happens mostly when itz defective/faulty..
check the following:
1)is ur m/b compatible..check with a substitute/standby..
2)if ur hdd is making any humming noise (like 'tic tic' or 'kirr kirr')..if so it is likely to be replaced..
3)replace the data cable with a standby n see..
4)all the power connectors n data cables r properly sitted n connected..
5)update/flash the bios..
6)check for firmware update and or raid drivers (as applicable)..
if u r not a professional, try contacting ur system admin/vendor....
Testimonial: "i am going to replace my harddrive because its making a ticking noise thanks, chamicar"
Wale Sarumi KomputerSolution
Level 3:
  • Lands Phones Master 6,993 Answers
Lands Phones Master
Level 3:
Answers
6993
Questions
Helped
1726621
Points
1262
Try to set the jumper of the hard disk in a way that will be compatible with your computer.
Enter your system setup by pressing "F8", wait till a blue back ground opens, search for device, you will find about four different drives, make sure they are all set to auto, you will also see the size of your hard disk, but if you can't find it, press "Auto". If it still does not show. Then probably it is not well connected. So you will have to check your IDE Cable and make sure it is well fixed.
Testimonial: "i am going to reolace harddrive because its making a ticking noise. thanks,chamicar"
Top Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Lands Phone Expert? Answer questions, earn points and help others
