While installing an application, getting an error message ''error configuration file is not well-formed xml'' in event viewer. I am using Vista home premium. Can anyone please suggest me?
Hello SriG... thanks so much for your response and help. However, the link you provided me doesnt seem to answer my problem. I am attaching the whole/series of error I am getting, so that it may give a clear picture of my problem. Looking forward for your help. Thanks very much again. Eventlogs below -------------------------
Log Name: HR.net Source: Installer Date: 23/11/2009 17:36:13 Event ID: 0 Task Category: None Level: Error Keywords: Classic User: N/A Computer: Samsung Description: Filename: \\?\C:\Windows\system32\inetsrv\config\applicationHost.config Line number: 267 Error: Configuration file is not well-formed XML
at Microsoft.Web.Administration.Interop.AppHostWritableAdminManager.GetAdminSection(String bstrSectionName, String bstrSectionPath) at Microsoft.Web.Administration.Configuration.GetSectionInternal(ConfigurationSection section, String sectionPath, String locationPath) at Microsoft.Web.Administration.ServerManager.get_ApplicationPoolsSection() at Microsoft.Web.Administration.ServerManager.get_ApplicationPools() at VizualInstallers.IISVista.AddIIS7AppPool(String AppName, ServerManager IIS7Manager) at VizualInstallers.IISVista.CreateVirtualDirectory(String AppName, String Path, String InstalledPath) at VizualInstallers.HRnetWeb.CreateVirtualDirectories() at VizualInstallers.HRnetWeb.Install(IDictionary savedState) ---------------------------------------------------------
Object reference not set to an instance of an object.
at VizualInstallers.InstallerUtilities.HandleException(Exception installException, Boolean writeLog) at VizualInstallers.WebServerInstaller.Install(IDictionary savedState) at HRnet_Express_Installer.InstallationController.InstallThirdPartyComponents() at HRnet_Express_Installer.CustomInstaller.FullInstall() at HRnet_Express_Installer.CustomInstaller.Install() ---------------------------------------------------------------
Object reference not set to an instance of an object. at VizualInstallers.InstallerUtilities.HandleException(Exception installException, Boolean writeLog) at VizualInstallers.IISVista.Install(IDictionary savedState) at VizualInstallers.WebServerInstaller.Install(IDictionary savedState)
Object reference not set to an instance of an object. at VizualInstallers.RegistryUtilities.WriteLocalMachineRegKey(String path, String Name, Object Value) at VizualInstallers.RegistryUtilities.AddRunOnceEntryForCurrentProgram(String name, String args) at VizualInstallers.Machine.AddRunOnceEntryForCurrentProgram(String name, String args) at HRnet_Express_Installer.MainForm.VistaIISRestart() at VizualInstallers.IISVista.Install(IDictionary savedState)Hello SriG... thanks so much for your response and help. However, the link you provided me doesnt seem to answer my problem. I am attaching the whole/series of error I am getting, so that it may give a clear picture of my problem. Looking forward for your help. Thanks very much again. Eventlogs below
Log Name: HR.net
Source: Installer
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Samsung
Description:
Line number: 267
Line number: 267
Just to give you a bit more detailed picture, I am trying to install a web based application with SQL 2005 as backend. The errors I am getting really doesnt make much sense to me whilst may give you some ideas.Just to give you a bit more detailed picture, I am trying to install a web based application with SQL 2005 as backend. The errors I am getting really doesnt make much sense to me whilst may give you some ideas.
http://support.microsoft.com/kb/960412 Follow this article and if this is what error you get in the above article, if yes then call 1-800-936-5700 to get the hotfix sent toyou. Please let me know, thank you.http://support.microsoft.com/kb/960412
You can't post conmments that contain an email address.
Log Name: HR.net
Source: Installer
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Samsung
Description:
Line number: 267
Line number: 267
