I have a procesor socketA AMD Athlon XP 2500 and a motherboard Matsonic MS8137C(+). Now the CPU is 1466Mhz. Before that CPU has a 1100Mhz. I selected jumper JMP to 133Mhz. I wait a solution please. My memory is DDR 256 100Mhz
So u did before ? what slots u have agp pci pci express ? and what one uusing ? what mobo
could pull video out
boot up then shut down hold power button in after u here sum beats then re put back in video what model video also does it need to be pluged in also or cheaper card or is it onbord video ?
well what video card man and what mobo need more onfo if u wanthelp ok i can ghuess
but wont help need to knew what mobo u have and video model /
try takling the card out 1st turn on with out it in then off then back innn ?
30 sec
try the back port if it has onbord also try that out put with your dvi plug or 15 pin blue vga plug in back ok of onbord video maby it defulted back to that
then once u see set bios to agp or whatever u use pci ect ?
ok now u sure u dont have onbord video also will the card only go in one slot ? brown one or
how did u reset bios also battery out and in ? or jumpers on 2-3 pin
will that video only go in one mobo slot ? agp or pci express do u know
is it a hi end card u plug in ? try differt 4 pin plug on it push it in good to mobo
ok longer grey new computer pci express what model video card uusing
re set screen
turn off your screen and back on once lol
out put u meen ya i know i meen what style is it to mobo agp 8x or pci were u plug it into mobo what slot do u know what model video
is that ati then or nvidia chipset
did u add ram ? try it with one stick of ram if not try other stick closest to cpu use that soekt for ram ok 1st dimmm k
Did you have the computer unplugged when you pulled the bios battery? Turning it off isn't enough. You have to unplug it and remove the battery. 15 seconds will be more than long enough
when u pull battery u upluged it corect ? main power pull it out
says on video card sumtiems ati or do u rember what video card driver uused
pull battery and unplug it as u do for few min ok
does your cpu fan spin ????? if not that could def do it
sounds like the CPU Fan detection is shutting down the pc. either the cpu
fan is no longer reporting RPM feedback correctly or something like that.
the trick is to have a fan that has good RPM feedback hooked up long enough
to get into the bios and disable the fan detection on the PC Health screen
even tho it works good doesnt meen its good ok bad sensor try anther fan pluged into that fan 3pin out
u pulled power off it also coreect must pull main balck power cord off back as u do ok
yes im stil here thinking reserching for u give me a min do u have pci video card u can test it off that get in bios to set back to agp ??? that may do it
ya im looking was busy for min on a labtop i had come in
pull main psp from mobo once 20 pin main conecter u know for min then back in also
do u have differt power reset the all ram and maby reset cpu chip
try anther battery in cmos 3v k from anther computer ok
might be mad mobo that model dint find anything else is it growned well all screws tight to mobo to case
yes it is a video card
how long do i let computer run when i pull video out
mother board is a matsonic ms81837c
i heard no beeps and it didnt work still no video
it has no onboard port i did everything you said and still no video
its a grey slot and it can only go into one
everything was working fine till i reset cmos jumper
the card itself has a s video slot on it and the monitior slot
samsung k4d261638e-tc40
tired reseting screen nothing
got me what kind it is how do you tell?
i didnt add ram
i didnt pull battery i just reset cmos jumper then put back in normal
video card says fcce on it like the mother board does
oka
yes processor fan spins and so does battery fan
cp fan and everything works good im going to pull battery and see if that works
i pulled battery and im waiting now couple of minutes
still nothing and tried fan thing
i always cut power before touching anything on board.my freind told me to always do that
i have 3 other socket a boards and yesterday i hooked them all up and resest cmos on them too and the same exact thing happend no video
i figured it has to has something to do with the socket a boards theres gotta be some easy way to fix this.if it did it to all 3 of my boards then shurly its done it to other ones
this realy sucks
you still there
well you know of any web sites that deal with matsonic boards
i have 3 different video cards i can use and i tried all 3 with the same results
oka ill let you research
find anything
i lot
by the way my mouse and keyboard arnt working either
any things at once
