HP TouchSmart IQ506t PC with Intel Core 2 Duo Processor T5850  ; 4GB DDR2-667MHz sy...  PC Desktop Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer freezes up - HP TouchSmart IQ506t PC with Intel Core 2 Duo Processor T5850 ; 4GB DDR2-667MHz sy... PC Desktop
Anonymous
Level 2:
Novelist:
  • Expert 136 Answers
  • Posted on Dec 09, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
136
Questions
0
Helped
36902
Points
405
In case your system freezes at system startup, it usually implies that there are way too many programs loading at startup. Therefore, to fix these errors, you will have to stop unnecessary programs from loading during the startup process. To do this, first check the Start > All Programs > Startup folder. If you see any unwanted programs listed here, right-click and select Delete, to remove them. Next, open the System Configuration utility by running “msconfig” from Start > Run. On the Startup tab, clear the checkboxes of the programs that you do not want to load during system startup. Select Apply and click OK to implement the changes and restart your PC.
Computer freezes due to hardware, generally occur when different hardware devices
The problems may also occur if the device driver of a particular device is erroneous. You can resolve these errors with the help of the Device Manager (Control Panel > System > Hardware > Device Manager.) In Device Manager, locate the faulty device—depicted with a yellow triangle containing a yellow exclamation mark, right-click on it, and select properties. Here, on the Resources tab, you can manually modify the resource allocation of the conflicting device
Thanks,
When I am reading my e-mails, my computer freezes up. I have to log off and then restart it. What is wrong
A computer locking up or freezing is often is caused by software related issues. ... Tip: If the computer has any malware, virus, or other malicious software it can also cause many problems. Make sure your computer is clean. Too many programs open.
Windows freezes or stops responding. - Computer Hope
www.computerhope.com/issues/ch000690.htm computer freezes up Google Search
tip
Install System Restore Software Deep Freeze
Faronics Deep Freeze helps eliminate computer damage and downtime by making computer
configurations indestructible. Once Deep Freeze is installed on a computer, any changes made to the computer- regardless of whether they are accidental or malicious - are never permanent. Deep Freeze provides immediate immunity from many of the problems that plague computers today- inevitable configuration drift, accidental system misconfiguration, malicious software activity, and incidental system degradation.
Deep Freeze
tip
Install Restore Software Deep Freeze
configurations indestructible. Once Deep Freeze is installed on a computer, any changes made to the computer- regardless of whether they are accidental or malicious- are never permanent. Deep Freeze provides immediate immunity from many of the problems that plague computers today- inevitable configuration drift, accidental system misconfiguration, malicious software activity, and incidental system degradation.
Deep Freeze
on Jul 28, 2014 • Computers & Internet
1helpful
2answers
Cannot uninstall deep freeze
uninstall it using administrator password
How i uninstall deep freeze software
HI Good day!! do the following
Disable Deep Freeze before uninstalling it.
To disable Deep Freeze:
1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
2. Enter your password and click OK.
3. If you have not yet entered a password you should be able to click OK without entering a password.
4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
Deep Freeze is uninstalled and your computer is rebooted.
How to un instaill deep freeze
To uninstall:
for more, you can visit Faronics site (http://www.faronics.com)
regards,
dzilog
I cant install new version of my anti virus
you need to install deep freeze again. After installing, restart the computer and uninstall it.
hope this will help!
Peace!!!
2answers
Microsoft applications off computer, computer keeps freezing
Not sure what you are asking for.
Computer freezing can be caused by a number of things. Does freezing occur somewhat randomly? Or only when you use a certain application?
2helpful
Want to uninstall deep freeze
Give this a go....
To uninstall:
Hope this helps.
Andy
R31 freezes up
Your computer shut down due a bad battery, Need to replaced.
Replace the battery first and see if your computer still freezing.
The reason(s) you may experience computer freezes, could be software related or hardware related; perhaps it's a combination of both.
Below is a broad list of some of common causes of computer freezes.
  • Memory
  • Video
  • Device Drivers
  • Bad Motherboard
  • Bad Devices
  • System Resources
  • Software
Top HP Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
