Whirlpool GU2400XTP Built-in Dishwasher Logo
Posted on Jan 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
D3 error code
I have a GU2400XTPwhirlpool dish washer that first had the saniclean green light flashing, cleared that with the two buttons, now i get a d3 code on the display and the water no longer sprays or even goes into a full wash cycle. I do hear a low buzz some for a bit then it drains. PlZZZ HELP.
Less than 2 yrs old.
Thank you !
  • 1 more comment
  • jaeg Jan 24, 2008
    No luck, i tried the heated dry-normal-heated dry, and it cycled all lights and started a wash cycle, water filled and the low buzz sounds started up for a while then the drain cycle started.
    maybe the D3 code means the motor/pump is bad since it no longer sprays water.
  • jaeg Jan 24, 2008
    Hi, the D3 did clear up but comes back if i try to run a cycle again then clears it self. I did find a broken glass but was able to recover the few broken pieces and i clean out the lower filter too.
    And yes this did happen from one day to the next. The first problem was the green clean light flashing but was able to clear it out with the buttons heated dry/hi temp. I will check the motor and let you know. Thanks for all the help !
  • Anonymous Oct 20, 2011
    It is a quiet partner iii sorry
Anonymous
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Jan 24, 2008
Anonymous
Master
Level 3:
President:
Answers
1314
Questions
6
Helped
908999
Points
3823
Try running it in service diagnostic and let it finish will check its self and clear error codes in less than 6 seconds push heated dry-normal-heated dry-normal and advise me
  • Anonymous Jan 24, 2008
    according to the tech sheet d3 is the software code for a tall tub dishwasher but the cycle tell me what i want to know is the d3 code still there or did it clear we aren't done yet pull the bottom plate off and on the motor is a start capacitor silver looking cylinder with two wires on it make sure one of those wires Inst loose let me know did this happen all of a sudden and did you find any broken or chipped dishes or galss in the unit
Top Whirlpool Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
