Nintendo Wii Console Logo
Posted on Dec 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 51420 - Nintendo Wii Console
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 364 Answers
  • Posted on Jan 01, 2011
Anonymous
Expert
Level 2:
Mentor:
Answers
364
Questions
0
Helped
87885
Points
393
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
From the Wii's main menu, select the Wii icon along the bottom left of the screen.
Select "Wii Settings".
Click the left arrow to get to Wii System Settings 3
Choose "Wii System Update"
Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
For any help click here
Anonymous
Level 3:
  • Master 1,234 Answers
  • Posted on Aug 26, 2010
Anonymous
Master
Level 3:
Answers
1234
Questions
0
Helped
300108
Points
1672
Error Code: 51420The Wii console is not able to connect to your wired router or modem.
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jan 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
2775
Points
20
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
1 Related Answer
Anonymous
  • 142 Answers
  • Posted on Oct 02, 2010
SOURCE: Wii Console: error code 51420...
Error code 51420
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
I cant get to connect to the internet it will give me an error code 51420
Hi there.
This error tells you that the Wii console is not able to connect to your wired router or modem. Please follow the steps in this link to fix this problem.
Thank you!
Trying to hook it with netflix keeps giving me an error code 51420
This should remove the error and allow you to watch Netflix.
2helpful
I cant get the internet to connect to the wii
I'm getting Error Code: 51420 when trying to connect to the internet with the Wii console.
This is our first time trying to make internet connect with the Wii console. I have a USB cable connect from Wii console to the Modem. Any help
Error code 51420 on my wii console. I am trying to establish a connection to the internet. I have a router which is working properly because i can get on the internet now. I have ran my ethernet cable...
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
I am trying to access the internet to get netflix on a used Wii. It is saying error code 51420. What do I do?
Sometimes this happens because servers go down for nintendo. If this problem persists it might be caused by a third party adapter that is used to connect your wii to the internet.
I am trying to connect to internet with my wii, to use Netflicks, i get a 51420 error code, can you help please
Hi, that error code only occurs when using the wired LAN adapter, so I'll assume you aren't using wireless.
Here are some instructions that I found to set the wired adapter up, hopefully they'll help: ttp://www.nintendo.com/consumer/systems/wii/en_na/getOnline/lansetupwii.jsp
Unable to connect to internet error code 51420
easy fix i used wii party my system then updated then i went to wii shop and updated again the whole system updated to the 4.3E and now able to use wii shop again
3answers
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
