Trying to put the code into my comcast remote...none of the codes they suggested work. what is the code?
SOURCE: I need device codes
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
SOURCE: need a universal remote control code for sony dav-dz 100
1903 will work for most functions, but not the DVD player buttons.
SOURCE: Remote
Hello creyn,
why dont you join both TV n Theater system remotes togather with rubber band?
SOURCE: Code for Comcast remote for Sony DAVHDX275
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
SOURCE: Cannot find code for Comcast remote to operate DVD
hi im having the same issue, have u managed to find an answer? rachaelhowell@comcast.net
