It all depends on what you want to do with it. It is not surely the fastest PC in existence, and probably won't cut it for "serious" gaming, but it's more than enough to run XP and Office applications, provided it has also enough RAM of course.
To answer your question yes that's a better cpu in every way, seed, cache ect. so will speed up processing data, but you will only be as quick as your slowest component, that usually begin the ram and or hard drive.
if you want to do some high end gaming or video work you should get a new rig.
rig is just another name for computer. if its just a internet computer, then the CPU you want is all you should purchase. enjoy:-)
Hope I have helped.
might just be your boot up, different motherboard and bios systems boot up at different speeds, i have a complex system with a few SATA arrays and i take about 1 and a half mins to get past POST screens before windows even loads.
Though this new cpu may help you by a few seconds, as would RAM, but i really would not worry about your boot time.
in that case the hard drive may have a bad sector within the platter, i didn't know about your defragging issue. you may need a new HDD, IDE drives are very cheap now, but before you purchase one, you might want to borrow one from a friend to test with in case the problem is still there. and if it fixes the problem, then you know its the hard drive and can purchase a new one.
im comparing it too a amd athlon 1350+ 1.35ghz
is it faster than a amd athlon 1.35ghz 1350+?????????????????????????????
well is it you have some slow replies
whats a rig?
i only need the computer for internet gaming and buying things thats all but i play games online anyway
yes i will give u full rating but could you tell me why my boot screen is a bit slow and how i could change the boot screen to make it faster
well thanks for your time but this other man was saying it is because of my harddrive i was starting to question my self like how can it be the harddrive
and also when i am doing a defragmenter too make my pc run smoother it freezes on 25% then i have too restart my computer
the harddrive is good it doesnt look as if theres any problems to it
Any faster then what? what are you comparing it to?
