I request for an address label to print but the envelope feeded keeps annoucing a paper jam.
> Home > Support & Drivers > Knowledge Base
Solution -->
Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes.
Printing envelopes from the envelope feeder
In the application, define the envelope size (page size). In the printer driver, select Tray 1, 2, or 3 (the tray you just loaded) as the paper source, select the envelope size, and select Envelope as the paper type.
Make a test print from your application to confirm that the orientation of your envelope is correct.
Printing envelopes from the Multi-Purpose TrayInsert the envelopes into the Multi-Purpose Tray. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
Place the side to be printed faceup.
The top of the envelopes should be toward the left of the printer.
When the front panel prompts you to confirm or change the paper type and size:
Press the Down Arrow key to scroll to Change Paper Type then press the OK key.
Scroll to Envelope and press the OK key to save your selection.
Scroll to Change Paper Size then press the OK key.
Scroll to the correct envelope size and press the OK key to save your selection.
In the printer driver, select Multi-Purpose Tray as the paper source and select Envelopes as the paper type.
To order envelopes click here. Make a test print from your application to confirm that the orientation of your envelope is correct.
From the Tools menu in Word, select Envelopes and Labels.
Enter the return address and sender address.
Select Options, then select Printing Options.
Select face up.
Leave Clockwise Rotation unchecked.
Orient the envelope feed method to be centered and the stamp end first.
Under Feed From select Multi-Sheet Bypass Feed.
Press Envelope Options and select Size 10, then select OK.
Note: Prior to printing, the printer must be configured for printing on envelopes via the front panel menu. These steps are listed below. Prepare each envelope by tucking in the envelope flap.
Insert the envelopes (maximum capacity is 10):
Short end enters first.
Side to be printed is face-up.
Make a test print from the application to determine the correct orientation of the envelope.
Adjust the Multi-Sheet Bypass Feeder (MBF) guides for the envelope width.
Open the Face-up output bin at the rear of the printer.
Set the front panel to match the media type loaded in the MBF.
From the Control Panel, press the Menu button until it displays Tray Menu.
Press the Item button until the Control Panel displays MBF Type.
Press the Value button until the Control Panel displays Envelope, then press Enter.
Press the Item button until the Control Panel displays MBF Size.
Scroll by pressing the Value button to select the appropriate size.
Press the Enter button to save the selection.
Press the On-line button to exit the menu.
From the driver:
Select Multi-Sheet Bypass Feeder (MBF) as Paper Source.
Return to the Top Select the appropriate size.
Select Envelope as the media type.
Send the job to the printer.
Select face up.
From the driver:
Not as straight forward as expected
