Brother DCP-7020 All-In-One Laser Printer Logo
Posted on Feb 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Message "Back cover open. Close back cover" on Brother Dcp 7020 printer
Milind Shetti
Level 3:
Guru:
  • Master 829 Answers
  • Posted on Feb 08, 2010
Milind Shetti
Master
Level 3:
Guru:
Answers
829
Questions
0
Helped
386176
Points
2380
This error is due to tray problem check if the back tray latch is not broken .also check the Fuser unit at the back if its not been fixed or loose contact.
Regards.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
540
Points
I was about to surrender, but tried again in a calmer mode and started checking everything in the paper path thru the printer.There's a small coiled spring that can come loose under the printer. This spring is connected to the plastic lever/sensor that tellls the printer there's paper in the drum/toner chamber.You should see it with the help of a lamp or flashlight, since almost everything under the printer is black plastic. You have to prop the printer on it's back to see it. there'a metal plate exactly below the paper feed rollers, you have take that plate out by removing the six screws that hold it in place. This is to check that the lever/sensor I pointed before is actually inside the hole that holds it in place. The spring, if its loose should be hanging by one of it ends using very small tweezers or needle nose pliers, you should be able to hook it back to the lever/sensor, it has a hooked end where the spring should hook to. The printer is working like a charm again!!! (IF THIS SPRING IS MISSING, IT SHOULD BE REPLACED WITH A SIMILAR ONE, IT IS ABOUT THE SIZE OF A BALLPOINT PEN SPRING, BUT WITH LOW TENSION, IT HAS THE TENSION OF A LEAF SPRING LIKE THE ONE IT THE BACK COVER OF THE PRINTER)
1 Related Answer
xptareq2000
Tareq Bin Mostaq Mostaq
  • 1449 Answers
  • Posted on Nov 22, 2009
SOURCE: The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
