IBM xSeries 346 Server Logo
Posted on Feb 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"how to change write through to write back in 7k" Problem Now!
Anonymous
Level 2:
Scholar:
  • Expert 121 Answers
  • Posted on Feb 20, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
121
Questions
0
Helped
68650
Points
308
You need to use download, boot from and use the ServeRAID Support CD and the RAID controller tools on that disc. You cannot modify RAID controller features on the 7k while it is operational and/or in use.
See ServeRAID support page at http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?brandind=5000008&lndocid=MIGR-62462
SANGYONG DISSEL ENGINE .WHEN TO CHANGE GEAR OIL AND AXLE OIL ?
New sint oils say the "can" be changed after 9k km... tried once but sounded awfull after 8K so now I change every 7k. for gears I do every 60K km.
Toyota 7k engine
no year.
no car stated.
you kidding right?
is it a carb car or EFI ?????
tell more get more..... for sure...
DATA:
7K (wiki)
The 1.8 L (1,781 cc) 7K was first introduced in 1983. Cylinder bore was 80.5 mm (3.17 in) and stroke was 87.5 mm (3.44 in). Output was 80 hp (60 kW) at 4600 RPM and 103 lb·ft (139 N·m) at 2800 Was available with a 5 speed manual & 4 speed automatic transmission. Available in both fuel injected and carburetted configurations, the 7K produces much more power and torque compared to the other K engines however it is a lot less 'rev happy' due to having such a large stroke.
7K is available in KR42 Townace SBV vans (1997-2007) using a large G52 5 speed gearbox (Same bellhousing to box pattern as W55), or automatic.
Applications:
My Honda cbr 750fj wont rev past 7k until i removed a pipe 4rm the carb and at 7k rpm blew just a lil into the pipe then i got my rpm back if i blow 2 much it revs down and want 2 cut out wtf and when i do...
No I dont think anyone else has tried that, but depending on what your blowing on, you are changing the mixture.
I suggest cleaning the carbs, make sure the choke is working correctly, and fit a new air filter element
6helpful
2answers
Valve tappet clearance of toyota 7k engine and honda civic vtec engine 1.6
7k clearances are ( HOT ) Inlet 0.008 in ( 0.20 mm )
Exhaust 0.012 in ( 0.30mm)
1helpful
2answers
1988 Kmx 125`hits short flatspot /stutter at 8000 revs
You changed the back pressure in the exhaust and that is what causing your problem either put the washer back in or have the carb properly jetted
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Sounds/feels "choppy" between 6K-7K RPM
Clean carburators, most likely has gummed up jets, don't blow out the jets without removing them first and even then sometime to remove all the **** you will still have to use something like a torch tip cleaner to do a good job.
1helpful
2answers
Can i install 7k transmission to 4k engine??ty
my dear u cant put 7k tranmission coz there u have to chang to things 1 is fly wheel & cluch & prussur plat set as well , when U finish it secandly u have to chang drive sharft face from gare side,after all u do in end u wont get the result for putting this gare coz its rato is low then 4k, so my friend i advice u put 5speed 4k orignal trasmission which is known as T50 ,i think so ,so conform with ur mec... or u can mail me on my address shahrukhali@hotmail.com, takecare hope u ll get the ans
Top IBM Computers & Internet Experts
Frank Fernandez
Sudeep Chatterjee
Sudeep Chatterjee
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
