My copier is showing a H 4 code that keeps flashing how can I reset
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit.
To reset press the following buttons:
Give that a try and good luck.
I think, you must call to service. It s may be need some ajesments and instruction.
Sharp AL-1631 H 4 code that keeps flashing
E7
03
Scanner position error
04
Exposure lamp blown
05
CCD calibration error
12
White level calibration error
14
Main board malfunction
15
Exposure lamp blown
L1
00
L3
00
L4
01
Main motor drive overloaded
L6
10
Polygon mirror motor not up to speed
H2
00
Fusing unit temperature error
H3
00
Overheated fusing unit
H4
00
The fusing unit doesn't heat up
U2
01
Counter error
04
EPROM error
CH blinking
Dev unit is not properly installed
In most cases this is a false code. Just look for my tip on this H4 code reset procedure and you may just save yourself a service call. Just search for Sharp AL series H4
Good Luck and Thank You for using Fixya
