Zanussi FJS1225W Front Load Washer Logo
Posted on Feb 19, 2010
Error code E50 what does this mean - Zanussi FJS1225W Front Load Washer
Anonymous
Level 1:
  • Contributor 10 Answers
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
Answers
10
Questions
0
Helped
8050
Points
46
E50 is a problem relating to the rotation of the motor if the drim will turn by hand you can be sure the motor is at fault ......most likeley the brushes worn out but possibly a new motor
3 Related Answers
Anonymous
  • Posted on Jul 22, 2008
SOURCE: E50 code
Had to phone zanussi. Catch 22!!
A
Anonymous
  • Posted on Aug 31, 2007
SOURCE: Error codes
This code is suggesting a motor related fault. Check the brushes in the first instance.
Anonymous
  • 49 Answers
  • Posted on Feb 19, 2008
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
AEG LAVAMAT 72800 ERROR CODE 50
Pease don't type in all CAPS Anonymous, it is considered SHOUTING and is harder to read.
It is a motor circuit fault
I have a AEG Lavamat 72800 which doesnt start any cicle ...
JustAnswer https://www.justanswer.com > UK Appliance Repair
Oct 13, 2011 - Hi. Ok lets get the correct error code out. To do this turn the dial to any setting and let it light up. Then press and hold the rinse hold ...
1 answer · Top answer: Hi Ok E54 means motor relay contacts sticking or motor down to earth. The relays are ...
I keep getting a error E50 on my AEG Lavamat model ...
Jul 5, 2012 - E50 is a motor circuit fault. Check the carbon brushes again, see if they've broken or stuck. Check the wiring to the motor. Let me know ...
1 answer · Top answer: Hiya, E50 is a motor circuit fault. Check the carbon brushes again, see if they'
https://www.google.com/search?q=AEG+LAVAMAT+72800+ERROR+CODE+50
2answers
My F1-3000N WNQ treadmill is stop and is showing E54 error, what does this error code mean?
If you wish to get some details treadmill error codes and calibration ; check the site linked here. http://electro-medical.blogspot.com/
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
SOURCE: E50 what does it mean, Hello & Welcome to FixYa E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok
Hello Baldur Thor, thanks for your inquiry!
From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
3helpful
Error code E50, what does this mean? We select programme, all the lights are on, we press start and E50 appears. What does this mean?
e50 is a motor error code.check the motor brushes are ok and check the insulation on the motor as this will give you an e50 error code.could also be a faulty wiring loom to the motor or a faulty main control pcb
E50 says the motor is overheated, they recomen you let it sit for 30min to clear.
It can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
1helpful
What does the error-code E50 means in a crayola Kiddycam 25070?
hi,
The "E50" error code indicates formatting a storage card has failed.I think the e50 error code happens when the camera is reading and/or writing to the CF card when the battery are dead or real low. The camera does not get to finish writing data and leaves an error on the CF card. Use new battery or fully charged battery. I hope this may help you,
regards,
kaybicks
Feb 27, 2010 • Cameras
Brother HL-5270DN printer says ERROR E50
Brother error e50
The error code E50 indicates a fuser unit failure - the fuser unit is no longer working and needs replacing. The error may also display itself on your Brother printer's front display panel as "Fuser Unit Failure" or "Replace Fuser Unit."
What Does the Brother Printer Code E50 Mean? - Small ...
14helpful
2answers
Electrolux ewf 1435 washing machine
Error 50
The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem.
Top Zanussi Washing Machines Experts
gerbee gomez
Sudeep Chatterjee
Sudeep Chatterjee
Kolbrun...
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
