Copystar CS-2050 All-In-One Printer Logo
Posted on Mar 01, 2010
How do I correct Error Code "C6400" - Copystar CS-2050 All-In-One Printer
Anonymous
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Sep 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
9817
Points
60
10871087 then 163 then start botton two times
  • Anonymous Apr 11, 2013
    Hi how do I get the service maintenance code so i can reset the "drum unit counter" ??? help! the 1087 didn't workunless I didn't do the steps correctly
2helpful
3answers
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
HOW I CAN FIX THE ERROR CODE C6400
heater problem press10871087 after press 163 reast
Error code C6400
check your fuser unit thermistor or thermostat or lamp as the following digita 1087 1087 and put 163
3helpful
Utax cd 1018 error code C6400
I have problem Utax cd 1018 he said technician call this code C6400
43helpful
5answers
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
C6400 error problem of kyocera printer
C6400
Contents: Zero-crossing signal problem
• The engine PWB does not detect the zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Check procedures/corrective measures: Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Causes: Defective power supply PWB.
Check procedures/corrective measures: Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
11helpful
3answers
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
2helpful
Hello, the c6000 is the Fuser heater 1/2 defective --- but is you are getting the c6400 --- is a zero cross signal error which means defective PWB. You must replace the engine PWB or the power source PWB and check for correct operations.
The cheapest route would be to replace the fuser but with the c6400 code I believe you would just be throwing your money away.
21helpful
3answers
SOLVING ERROR CODES
i have problem in my copy machin kyocera fs-1118  this problem is erreur c6400
Top Copystar Office Equipment & Supplies Experts
Sudeep Chatterjee
Sudeep Chatterjee
George Mclaughlin
Grand Canyon Tech
Grand Canyon Tech
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
