Approximately every other wash stops mid-way and shows up the error code E90. It occasionally will continue the wash after pressing pause/start a few times Can you help solve what this is or how it can be fixed? Thank you.
SOURCE: Error E90
That happened to mine, and apparently it is the connection to the control panal at the front of the machine or the desplay unit (4 blue wires). Take the top off and wiggle them around or re-connect if any are loose. Mine worked for one wash and then started displaying E10........so i'm not amused and I think i may end up getting a hotpoint!
SOURCE: washer whilst washing keeps flashing up with E90
Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
SOURCE: Electrolux 1087 E90
When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
what can i do ?
I found out the hard way that it's because the drain is blocked. Check the filter and even get a torch to look to make sure there is no coin or piece of wire jamming the pump.
I have exactly the same problem, only now the washing machine won't even start
