Dual Electronics CECT P168 Cellular Phone Logo
Posted on Mar 15, 2010
How do i get java settings on my i9+++ - Dual Electronics CECT P168 Cellular Phone
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Mar 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
2672
Points
19
There are currently no avaible java setting for this model phone, goto java and information in java settings. should be java versoin 2 or above. i recently sold this phone to purchase a newer model. i also have a cd/dvd with verious software and drivers etc including firmware (flash cable required)
4 Related Answers
Anonymous
  • 12 Answers
  • Posted on Feb 28, 2009
SOURCE: I have the Cect I9 phone w/Java
Here is directions for internet setup for AT&T on i9:
Watch the YouTube video on internet setup for AT&T WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to WAP@CINGULARGPRS.COM
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Email will not work with any server that requires smtp authentication (which is pretty much all of them here)
There is no java in the browser. Forget it. There is also no java loader so there is no downloading java games. Copying them to the SD card won't work either. No java loader so the file will be unrecognized.
Wap services like gmail, yahoo email and wap based instant messagers work fine. Make sure you have a good unlimited feature so you do not incur overages from over using your new toy.
SALMAN NASEER
  • 1011 Answers
  • Posted on May 05, 2009
SOURCE: I would like to know how to delete java games in i9 3g
dear,
just go on java or java games and then go to option and delete them one by one...
if that games are built in... i mean to say if there are pre installed java games then u cant delete them because they are part of mobile software....
hope u understand the matter.
dont forget to rate it....
regards,
Anonymous
  • 61 Answers
  • Posted on Sep 28, 2009
SOURCE: how do you change the java settings on the cect i9 3g?
*#0044# dial this code. your phone will change into English manual.
mobile phone wholsale: www.eshopbing.com
Anonymous
  • 1285 Answers
  • Posted on Jun 14, 2010
SOURCE: how do i delete the java games on my cect i9
Being that the game is on the cell phone memory not the external memory... be very cautions on deleting...go to the game it self and go to options (you can delete from cell) before starting
5helpful
Settings manual for Sciphone i9 3G
here ;
http://search-manual-online.com/pr-log-sciphone-i9-3g-dual-card-java-cell-phone-manual.html
May 10, 2010 • Cell Phones
1helpful
How do you change the java settings on the cect i9 3g?
I9 3g java installation problems
i9 3g is a secure telephone so you wont be able to inistall any java game.
Jul 03, 2009 • Cell Phones
I NEED HELP REPAIRING MY I9 SCREEN
There are basically two ways to do this. You can get online to the Java website via your WAP browser and enter in the code for the CECT installation ((wap.GetJar.com and then quick the download code 30827.) I usually download via USB though as this puts a copy onto my computer (in case it accidentally gets deleted) and it doesn?t cost any money or data to do this. For the Java installation, go to the get jar website. Make sure that you have the device set to CECT A100 (the CECT default.) Connect the phone to the computer via USB. Hit the mass storage icon on the phone. Click on the jar file that you want to download. Click save. Next, find the drive that your phone is listed under. (For me, this is K:/, but it may be something different in your case.) Click OK. Then, unhook the phone from the USB. Go into the document icon on the phone. Find the received file and then scroll down until you see the browser and click it. Then click ?install.? Now, you?ll go into Java icon. You?ll see the browser in the list of Java files. Then click launch. Opera should launch and you can start browsing. Most often, when something goes wrong here, it?s because the data, WAP or Java settings aren?t correct. You?ll need to go in and set them up depending upon your carrier. For example, if you use T Mobile, you?ll need to input the T Mobile WAP, port, and data settings. Typically, you set the data first, then the GPRS, the WAP, and the MMS. Finally, go into the JAVA settings and make sure that T Mobile (or AT&T, or which ever carrier that you are using) is reflected. There are many resources that will give you the Internet settings for almost every applicable carrier that you can think of. If for some reason you can?t get online, I?d check to make sure the phone isn?t set to the original Chinese or factory settings. To view video, close up photos, full specifications, and real time rock bottom pricing on the CECT i9 please check out http://i9clonephonereview.com/ If you need a USB cord for the i9 (or other accessories including internet, MMS, or WAP set up instructions, cases and skins, unlimited data sim cards, memory cards, batteries, etc,) please visit http://i9accessories.com
3helpful
dear,
regards,
May 05, 2009 • Cell Phones
5helpful
2answers
Please tell me exactly how to put java apps and movies on the i9
Ok, Its pretty simple to add java apps/games and movies to your i9. just
1) connect your phone to your pc via the usb.
2) go into your i9 phones memory card (the first of the two letters) i.e I = phone memory , H = memory card.. so go into the H drive.
3) Create a folder call 'JAVA' and simply drag your downloaded apps/games from your pc into your 'JAVA' folder on your memory card!
4) When you disconnect you phone, go to java in your phone menu then you can install the apps/games.
(step 3 only need to create 'java' folder once)
For movies
1) repeat step 1 and 2 above ^^
2) drag the movies from your pc into 'Movies' folder on memory card
3) disconnect phone from pc and you can now watch on your phone!
Note: i9 phone supports 3GP, AVI format only.
My i9 phone's slide to unlock feature wont work
THE I9 IS A JAVA BASED JAVA APP PHONE THE JAVA APP THAT RUNS THE SLIDE TO UNLOCK FEATURE HAS MALFUNCTIONED THE ONLY WAY IS TO HAVE A TOTAL FIRMWARE RESET BUT AT THE MOMENT CECT ARE NOT SUPPORTING THIS YOUR ONLY HOPE IS TO CONTACT THE SELLER OF THE PHONE AND TRY TO GET A REPLACEMENT HOPE THIS IS OF SOME HELP THERE IS A CECT FORUM IF YOU SEARCH GOOGLE
10helpful
4answers
Free games for i9 phones
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
Hope that helps.
9helpful
9answers
I want to load Games on to my cect i9 touch screen phone, can you
I'm sorry to say that that guy is wrong because the CECT i9 does have java depending on who you purchase it from. If you want proof go on youtube and look at some videos of people actually downloading java games to their phone.
Top Dual Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
