Won't heat...ducting is clean
heat sensor on the control board above the drum looks like the black wire got a little hot as there looks to be some melting around the terminal plug (would this cause no heat?) how do I check to see if it is still functional?
If that is not the problem...what are the ohm values for the two thermostats and the heater element?
Any idea on the cost of these parts for this particular dryer:
Control board
thermostats
heater element
Thank you in advance for any and all help.
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
SOURCE: i have a samsung dryer
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101
