Oster 6812 / 6813 / 6814 16 Speed Blender Logo
Posted on Mar 27, 2010
Is there a reset button
Oster 18speed blender is there a reset button tired to blend a drink. Started a little slow and then quit, waited a few minutes tried to start it, but doesn't work
5 Related Answers
Anonymous
  • 619 Answers
  • Posted on Jan 14, 2008
SOURCE: blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Bruce Showalter
  • 133 Answers
  • Posted on Mar 15, 2008
SOURCE: Help me revive my dead Oster blender
Check the motor brushes. They may be worn out. Also, since the 1980s, many electric motors have a thermal fuse in them. This unit "blows" when it gets to a certain temperature.
This fuse looks like a 22-caliber bullet and its pointed end is usually colored. If you have an ohmmeter or continuity checker, see if current will pass through the fuse. If not, you can try to replace it. Most times, the fuse is attached with crimp-on connectors. Replacements can be soldered in, if you put a clip-on heat sink between the fuse body and the soldering iron.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Mar 21, 2009
SOURCE: Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jun 04, 2009
SOURCE: poor function of my Oster classic blender
Yeah, the blades probably need to be replaced. The replacement blade assemblies for most models can be ordered directly from Oster - their phone # is 1-800-334-0759 - you have to go through an elaborate menu tree to get to the right place.
protek480
Craig Butler
  • 1730 Answers
  • Posted on Nov 06, 2009
SOURCE: blender 6812 does not start at all
Flip it upside down and take the bottom off and look for a fuse.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Top Oster Blenders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ADMIN Andrew
ADMIN Andrew
Mike Cairns
Mike Cairns
Are you an Oster Blender Expert? Answer questions, earn points and help others
