LG Electronic Window Air Conditioner Logo
Posted on Mar 27, 2010
My Reset button wont reset
My reset button on the AC power cord wont reset. i press the button in and it clicks but the green light doesnt stay on. i just hear the clicking noise only...how do i fix this? one time my brother made the green light turn on by pressing the reset button hard but it stopped again and it wont turn back on. could it be the outlet that i am plugging the power cord into? I am willing to pay for this repair so i dont have to buy a new LG AC.
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Mar 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
2672
Points
26
Just guessing, here. The reset is actually a "Ground Fault Interrupter" called a GFI. It's there to cut of power in case of a dangerous electrical condition--which you probably don't have.
Did you unplug the unit? If not do so, let the GFI cool for several minutes, and try to reset again. They're pretty hard to push in, maybe use a fingernail, you must hear a click or it's not reset.
Is there water in the outdoor unit, or is it filled with snow? This is the most likely cause of an actual GFI fault.
If the GFI itself has failed (unlikely), you could replace the entire power cord. You should then maintain safety by installing a GFI circuit breaker on that circuit, or you'll be in violation of codes that might affect your homeowners insurance.
There could actually be a problem with the unit. This would be that an electrical wire has come loose and is contacting the metal chassis, creating a shock hazard. Unlikely but possible.
If the receptacal you're plugging into is old and worn it might the problem. Worn receptacles might actually have tiny electrical arcs inside, which can trip a GFI. At a couple of bucks (DIY) it's worth a shot.
If there's actually an electrical fault in the unit it can be found and repaired, but the cost of repair could very well be more than it's worth. Warranty?
Top LG Heating & Cooling Experts
Sudeep Chatterjee
Sudeep Chatterjee
Paul Bade
Frank Fernandez
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
