Hard reset or Factory reset will restore the phone back to its factory settings; the way it was when it was first bought or the way it was when it left the factory. Note that this will erased the entire phone's memory (NOT memory card) and settings to the way it was when it was first bought.
How to hard reset or factory reset T-Mobile G1 phone:
Switch off your G1. *If it won't your phone won't switch off, take out the battery and reinsert it after a few seconds.
Now press the 'Power' key and 'Home' key at the same time and hold it for 20-25 seconds.
Then you will see on your screen a yellow triangle with an exclamation mark in the middle.
After that, press 'Alt+L' key on the QWERTY keyboard (to clean the phone completely).
Next, press 'Alt+W' key (to factory reset it)
Again, press and hold 'Power' key and 'Back' key at the same time for 20-25 seconds.
You would have to perform a factory reset to get back into the device. This removes all data on the tablet so if you can find the password that would be best. To perform factory reset please follow those steps:
1. Power the device off.
2. Press and hold the Volume Up key and the Power key simultaneously to power on the device.
3. Release the Volume Up key and the Power key when the Samsung logo displays on the screen.
4. Use the Volume keys to select Recovery Console then press the Power key.
5. From the Recovery Console screen, use the Volume keys to select Wipe Data/Factory Reset then press the Power key.
6. Use the Volume keys to select Yes then press the Power key.
7. Once the Wipe Data / Factory Reset has completed, use the Volume keys to select Reboot System Now then press the Power key.
8. After a Wipe Data / Factory Reset has been performed, the device will need to go back through the activation and setup process
Restore factory default settings When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings. All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe" Press the Menu key twice. Scroll to Options and press the Navigation key. Scroll to Security and press the Navigation key. Scroll to Security Wipe and press the Navigation key. 2. Restore factory default settings Highlight Emails, Contacts, etc., User Installed Applications or Media Card and press the Navigation key. When the box next to the menu item is ticked (V), the selected data will be deleted. Highlight the field at the bottom of the display and key in blackberry Scroll to Wipe and press the Navigation key to restore the factory default settings. Follow the instructions on the display
Performing factory data reset ( master reset or hard reset ) Samsung Galaxy Admire 2 SCH-R830C via External Hardware keys buttons by Entering Android System Recovery:
Turn off the device
Remove the battery about 10 second and reinsert, remove sim card and sd card
press and hold both the Volume Up key and the Power key until theSamsung logo is displayed.
Press the Volume Down key to scroll to wipe data/factory reset.
With wipe data/factory reset highlighted, press the Power key.
Press the Volume Down key to scroll to Yes - delete all user data.
Press the Power key to confirm.
Press the Volume Down key to scroll to wipe cache partition.
With wipe cache partition highlighted, press the Power key.
Once the wipe is complete, press the Power key to select reboot system now.
Warning! All data will be erased from device memory, including system and application data, settings and downloaded applications. Back up your important data. The device will restore to factory settings.
In Run screen enter the number whose factorial you want to calculate, then press OPTN. Using F6> pan the tabs till you see PROB. Press the key that is under the tab. You will find the factorial function.
Yes, you have PATS II. There is a tranceiver on the ignition barrel and a transponder in every factory key. If the transceiver cannot read your key, the red security light will blink rapidly.If this happens, make sure you are using a factory key and there are no other factory keys near the switch. If it continues to blink rapidly, you might try removing the PATS ring from the key barrel and placing a factory key in the center of the ring. I have done this successfully in the past. If it works, tape up the key inside the ring and place it in the open space in the steering column shroud. Then remove the transponder from any other factory keys. You can then have keys made at a hardware store, as your one transponder inside the column will constantly respond to the PATS system.
