Now THIS is an old school problem. Way back, memory resident space was assigned to help with IO operations. This error happens when there's not enough memory to complete an operation with a given piece of hardware. I haven't seen this in ages! It has to do with IRQs. I assume you're dealing with a custom legacy application on your POS equipment, or whatever you're using is taking an older approach to getting things done. Here's some information from Microsoft on why the problem happens and how to fix it. Enjoy!
http://support.microsoft.com/kb/145799
What is a stack overflow?
In
software, a stack overflow occurs when too much memory is used on the
call stack. The call stack contains a limited amount of memory, often
determined at the start
of the program. The size of the call stack depends on many factors,
including the programming language, machine architecture,
multi-threading, and amount of available memory. When too much memory is
used on the call stack, the stack is said to overflow, typically
resulting in a program crash.(http://en.wikipedia.org/wiki/Stack_overflow)
Please
Note: Since the website is not hosted by Microsoft, the link may change
without notice. Microsoft does not guarantee the accuracy of this
information.
Mostly, this issue is caused by software conflict. Please take following steps to check if it is a add-ons issue.
1.
Open Internet Explorer by clicking the Start button, and then clicking Internet Explorer.
2.
Click the Tools button, and then click Manage Add-ons.
3.
Under Show, click All add-ons.
4.
Click the add-on you want to disable, and then click Disable/Enable.
5.
Repeat step 4 for every add-on you want to disable/enable. When you are finished, click Close.
