Canon PowerShot S2 IS Digital Camera Logo
Posted on Mar 18, 2008
E18 error Where did you send your camera for repair?
  • 4 more comments
  • damit666 Mar 25, 2008
    The lens will not retract and E18 appears in the viewer.
    I have tried the battery cover and memory cover that is described in the manual but to no avail?
  • Anonymous Mar 31, 2008
    My Canon Powershot S2 is also giving me the E188 error when I use my zoom, this is out of the blue and for n o apparent reason. is there a fix? Karen Corson
  • Kayray2 Mar 31, 2008
    My Canon Powershot S2 is also giving an E18 error message when I xoom, is there a fix? thanks
  • Anonymous Apr 21, 2008
    When powering on the lens will not extend and E18 appears on screen. The motor grinds as if it is trying to move the lens but cannot.
  • Anonymous May 03, 2008
    I am also having trouble with the lens not retracting and E18 appears in the viewer.
  • sharib May 11, 2008
    I am having the same problem. But this all started when I dropped my camera on the kitchen floor. I could get it to work for awhile, although it drained batteries terribly. Eventually it just stopped working altogether, now the lens is stuck out and I get the whirring sound when I try to turn it on and then get the E18 error.
Anonymous
Level 1:
Scholar:
  • Contributor 46 Answers
  • Posted on Jun 01, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
46
Questions
0
Helped
9222
Points
81
Hi all.
An E18 lens error or a "lens error restart camera" message is almost always a problem that must be sent in to the service center for repair. Though most often the result of a fall or other physical impact, they can occur spontaneously. Like a car stripping its gears, the lens motordrive mechanism has gotten off track. Often the camera will make a grinding noise as the camera lens attempts to track back and forth and occassionally the unit will beep several times and turn itself off.
Unfortunately most point and shoot cameras have very delicate lens mechanisms and it doesn't take much force at all to cause this to happen. Very often you may inadvertantly obstruct your camera's lens with your hand when holding the camera and turning it on. In these cases it is often possible for your lens to correct itself by actually turning the camera on and off several times (restarting camera). In the case of falls or drops, however, the impact damage is often uncorrectable by simply restarting and the unit must be sent in for service at that time.
If this happens to your camera through no fault of your own and you are still within your twelve month warranty period, simply send the camera in for service and the unit will be repaired at no charge. If you are outside of your warranty period OR it is determined by a technician that impact, liquid, or grit (sand or dirt) damage is at fault then you will be assessed a repair charge (even if within your warranty period).
Typically customers with out-or-warranty repairs will have a choice of either repairing their camera at the stated charge or (depending on the camera model) taking advantage of the Canon Loyalty Program in which they may opt to select a specific refurbished camera model of slightly higher model design - at a discounted price.
Hopes this helps.
Sincerely,
HeavyDLB
Top Canon Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
