Bosch SHU5315UC Dishwasher Logo
Posted on May 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the Control Module?
What tools are needed for the repair. What is the level of difficulty in getting to the Control Module?
Anonymous
Level 3:
  • Bosch Master 2,605 Answers
  • Posted on May 03, 2010
Anonymous
Bosch Master
Level 3:
Answers
2605
Questions
0
Helped
1133016
Points
11111
Actually all you need is a #20 torx screwdriver, a flat screwdriver and maybe a pair of needle nose pliers, but it can be done without the pliers if need be. The level of difficulty is hard to say since everyone has different and unique skills, but generally on a scale of 1 to 10 I`d say is likely a 2 - 3 depending on ones skills.
May I also inquire as to why you`re replacing the control ? Are you aware that typically the only thing which causes an error is the heater relay solder joint or the plastic tabs breaking off the casing which houses the control ? Did you know both are repairable ?
Anyway, just curiosity on my part, I digress.
**SAFETY FIRST - turn off the circuit breaker to the dishwasher before attempting any repairs or service to the unit**
I have a complete training manual I can send you if you`d like it, but you`d need to provide your email address, I can`t post it here it is adobe "pdf".
1) Remove the screws along both sides of the door panel until it is able to be removed, there will be either 2 plastic blocks which will fall out or molded styrofoam inside the panel, set the blocks and panel aside out of your way.
2) remove the screws around the perimeter of the control leaving the 2 ( one on each side ) facing away from the panel for the last.
3) once all the screws are removed the control fascia will be ready to pull away from the inner stainless steel door skin.
4) the fascia ( plastic cover with buttons/control face ) can now be separated from the inner control panel frame. If you observe closely you`ll notice it is only held together with tabs which need to be gently pulled away from the metal frame and then the fascia should pull off.
You should now be left with just a metal frame with the latch, power switch & rod and control board held in it.
5) All the wires in the bottom of the control will typically only go in one place, but it`s best to take a photo or mark them anyway...better sure than sorry right ? Remove the wires.
5) the plastic control casing is held into this metal frame only be tabs as well, push them inwards on one side and tilt the entire control back ( like it where hinged) and it will come right out.
6) This step should be much easier now that you`ve gained experience during the dis-assembly, reverse the steps to re-assemble it.
**if your door panel had the plastic blocks, they can be a pain to put back for one not experienced. The easiest way is to leave the two side screws out of the control panel to give it room to move into place at the top first and then down over the blocks.**
If you need help we`ll cross that bridge when we get there, get the control issue looked after first.
Let me know how you make out and if you want that service manual I can send you via email, it`s not very big...maybe 6MB or so.
Good luck
macmarkus :)
  • 1 more comment
  • Anonymous May 18, 2010
    Hello again,
    Just was wondering about how you made out with your control replacement, so I thought I'd try to do a follow-up. Did you get the control replaced, or repaired ?
    Please let me know here at "fixya" so I can stop wondering, ha ha !
    Hope you where successful in any event.
    macmarkus :)
  • scott morgan
    scott morgan Jul 25, 2014
    Hi Mark,
  • scott morgan
    I'm having trouble with my Bosch SHX46B02UC/14 dishwasher. Original problem was 3.5 hour cycle time due to a solder joint burned out on the pc board. Repaired that and the dw wouldn't do anything more than hum intermittently and leave some water standing in the basin. Replaced the control module. Still doing the same thing. I was wondering if you could offer some insight and send the service manual you mentioned. If so, my email is scottmorgan83@hotmail.com. Thanks for any guidance you might give me.
Top Bosch Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
